Tip & How-To about Lenovo Ideapad A1 Tablet White Idea Pad 16gb 7" Display Wifi Android
DISSEMBLING AND ADAPTER CHECKING
LENOVO IDEA PAD FLEX10
HOW TO CHECK THE AC ADAPTER
You are here because the computer fails only when the AC adapter is used.
• If the power-on indicator does not turn on, check the power cord of the AC adapter for correct continuity and installation.
• If the computer does not charge during operation, go to "Checking operational charging".
To check the AC adapter, follow the steps below:
1. Unplug the AC adapter cable from the computer.
2. Measure the output voltage at the plug of the AC adapter cable. See the following Fig
For more pictures and description check the bellow link. On the search tap type lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
Lenovo Ideapad A1 Tablet White Idea Pad 16gb 7" Display Wifi Android Logo
I have an Lenovo Idea Pad S10-2, the laptop knows the battery which shows to be 100% full, but if i remove AC Power, there is no switch to battery as well if i try to start from battery
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard. Take out the battery and unplug the power adapter from the computer. Press and hold the power button for 10 secs. Put everything back in then tunr on the computer and observe the issue. If same thing will happen then the problem is somewhere in the motherboard connecting to the battery terminal. You nedd to call Lenovo Support at 18774536686 then option number 2 for repair of the computer.
Thank you for using Fixya!
Feb 21, 2011 | Lenovo IdeaPad S10-1208Uw Netbook
i am not able to open my laptop lenovo G460
Hi kabi_a11,
If you're unable to turn on your laptop there's a big chance that you're having power issue. Consider checking your Battery, AC adapter and DC In port.
1. Basic troubleshooting for battery is by reseating it. Kindly make sure to put it back properly.
2. For the AC Adapter, check the light indicator for it. If it's not defective you'll see the blue light on the brick. You may also try using other AC adapter with same power supply. And if other AC adapter works with your PC then it's the AC adapter that goes with your PC needs to be replaced.
3. One of the possible cause for your computer not to turn on is because the DC In port for the machine is loosed. No power will flow from your AC adapter to your PC.
If after checking and still computer won't turn on I will now recommend you to contact the manufacturer. Lenovo offers repair if machine is under warranty.
Hope this helps.
Thank you for using Fixya.
Feb 16, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
My laptop is not being charged or getting any connection from the AC adapter. I purchased a Universal adapter, but my model LM6232 is not compatiable with the Universal. So, I purchased an AC adapter specifically for this model, yet upon recieving it today, my computer is not recieving a charge.
hi
sir/mrs.
i guess the problem that u r facing with ur laptop isn't
about the adapter but its about the outlet power of ur laptop.
check if its not damaged.
if it does try to replace it by dissembling ur computer and use soldering kit.
please dont forget rating this comment.
if this not helping u tell me so i can help u further!!
Aug 20, 2008 | Gateway Computers & Internet
614 people viewed this tip
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
