Tip & How-To about Garden
Easy ice removal
Fast easy and safe way to remove ice from your windshield, put rubbing alcohol in a spray bottle and spray the windshield. watch the ice melt away.
Garden Logo
My refrigerator smells bad
Try this
Clean the refer with mild soap and water and leave open until it drys.
Take one part rubbing alcohol and one part vanilla, put into a spray bottle and spray all the cracks and crevices.
Roll newspaper into loose balls about the size of soccer balls and put threw out the refer,
Close doors,turn machine on and run 24 hours with only newspaper in it.
Throw away newspaper next day and odors should go with it!
Mar 04, 2014 | Sub-Zero 642
Ac smell in 2009 Mercedes c300
Check drain and unclog if required.
Remove air cabin filter (see you tube for instructions). Make sure it is done in a clean place so no dust or dirt gets in while you do this.
Block Air Cabin filter opening with duct tape.
Set fan to 50% (3/4), temperature to minimum
AC must be OFF
Open hood and using a Spray bottle, spray half a bottle of Alcohol 70% into the air intake vents at bottom of windshield
Turn off fan
Let it sit for 30 to 60 min
Set temperature to max and fan to max
Open hood and using a Spray bottle, spray the second half (250ml) of a bottle of Alcohol 70% into the air intake vents at bottom of windshield.
Turn heater and fan OFF
Take off duct tape and replace the air cabin filter (new one is better)
If you don't take off the air cabin filter, a lot of the alcohol or disinfenctant (like Lysol) may be stuck in the filter causing an irritating smell.
Replace Air cabin filter if possible.
Jan 30, 2013 | Mercedes-Benz Cars & Trucks
how do i clean the tv screen on my flat screen tv
Get a soft fine cotton cloth, dry and clean. Never use paper towels or tissues or even a bath towel as these will scratch the screen. Get some distilled water. You can buy distilled water at the grocery store. Get a clean spray bottle with a very fine spray and fill the bottle with the distilled water. Now add just a little isopropyl alcohol (rubbing alcohol). Spray the liquid on the cloth and swipe from top to bottom on the screen until the screen is cleaned. Distilled water is better than tap water because it is more pure with minerals removed which would scratch the screen. The alcohol acts as a solvent to help remove dust and deposits. Never touch the screen with your fingers as they have oils which will leave a film on the screen. Never use a lot of alcohol. You want mostly water with just a hint of the rubbing alcohol mixed in.
Mar 26, 2011 | Televison & Video
I have a a pick-up B-3000 extend cab and the rear door are stuck from the button. How can opens these doors?
  • If it's simply the car door lock that's frozen, try heating your car key with a lighter and inserting it into the lock. The heat from the metal may be enough to thaw the ice and allow you to unlock it. To ensure that the lock will not freeze again, spray it with WD-40.
  • If the entire door is frozen, carefully chip the ice away from the edges with a scraper. Be careful not to scratch the paint of the car. If you cannot chip the ice away, try pouring some windshield washer fluid on the icy areas; windshield washer fluid contains alcohol and this may help melt the ice.
  • Use a blow dryer set on high to melt the surrounding ice.
  • The best way to open a frozen car door and prevent future frustration is to purchase de-icer. Many good brands are available at hardware and auto shops - just be sure the solvent displaces moisture and leaves behind a lubricant. If the lock itself is frozen, spray the product directly into the key hole, wait five seconds and then put in your key and try to turn it. Most of these products have straws that help direct the product out of the can and into small areas, making the de-icing process easy.
    Once the door is open, consider spraying the de-icer along the hinges of the door to keep other parts from freezing. Keep the de-icer in your home or garage where you can easily find it. Do not keep it in your vehicle. Having de-icer in your frozen vehicle won't do you much good.
Dec 05, 2010 | 2001 Mazda Pickup Regular Cab
548 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
