Tip & How-To about Vehicle Parts & Accessories
Winter car starting
During cold winter morning starting many cars have hard starting problems..Try this, before starting your car turn the switch to on but not the start position..if your car has auto on and off headlights let them on if it does not, turn them on..then listen for the fuel pump to run then stop about ten "10 " seconds..then turn off your lights and start the car..What this does is fully prime the fuel system and injectors plus energize " wake up the cold battery " Results quicker starts with less ware on the starter and longer battery life..Try it works for me...Good luck..
Vehicle Parts & Accessories Logo
car wont start during cold winter mornings
Clean throttle body and change fuel filter.
Jan 28, 2016 | Cars & Trucks
cool mornings it doesn't want to start ,i have to turn the key to start and let it off several times and it will eventually start after that it starts fine all day and starts fine on warm days
How to Start a Car in Freezing Cold Winter Weather
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowFreezing cold weather can take a toll on car batteries. ... It's much more difficult to start a cold car with a mostly-empty tank, so do yourself a favor and gas up ...
Why is it so hard to start a car in the winter? - HowStuffWorks
auto.howstuffworks.com/car-driving-safety/.../start-car-in-winter.htm
To start a car in winter, your engine has to work extra hard. Learn the top 3 reasons your car is hard to start in cold winter weather.
Debunking 5 Cold-Weather Car Myths - Popular Mechanics
Nov 21, 2015 | Cars & Trucks
1999 Mazda B400 Picup hard to start in Cold weather
Try spraying all the distributor & your leads with WD40 this will cure your problem for sure. Best Wishes. Malcolm Campbell.
Jun 20, 2017 | Cars & Trucks
My 1997 Olds Achieva fires up and then dies immediately
Your starter will start to do nothing but click when you try to start the car. And you will have problems with it constantly freezin up
Dec 10, 2009 | 1997 Oldsmobile Achieva
hard starts in the morning even though replaced most parts
Check the power to the cold start injector. (it's only going to have fire for a few sec. after the key is turned on). If the fire is good, replace the cold start injector. This injector is activated for a few seconds when the engen temp is low to add a little fuel lower down in the intake and closer to the pistons.
May 20, 2009 | 1994 GMC Jimmy
607 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
