Tip & How-To about LG WM-2277HW Front Load Washer
LG washer error code helps
LE error code is very common and most likely is from a bad motor position sensor also known as a "hall" sensor. Easy replacement and inexpensive part, around $20. Best video is from appliancepartspros.com. Part is available from them and online like ebay. Just try to make sure it is an actual LG oem part, not an oem equivalent part. About a 30 minute time frame if it's your first time. Really not very hard. You just need a Philips screw driver and 10mm and 17mm socket and socket wrench.
LG WM-2277HW Front Load Washer Logo
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
how do I fix a loose or locked up drum that generates LE errors?
you sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
Aug 30, 2015 | LG WM2016CW Front Load Washer
Le code
LE (Locked motor error) the rotor or stator of the motor assembly is faulty.
Mar 19, 2014 | LG WM-2277HW Front Load Washer
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
May 22, 2011 | LG WM-2277HW Front Load Washer
I have an lg wm2277h washing machine, i keep getting LE error at display how can i fix this?
This is caused by a bad Hall Sensor. when it is bad it tells the computer that there is too much load on the motor, therefore giving you the LE code, otherwise known as a (Locked Rotor Error). It is cheap and fairly easy to replace, the part can be ordered at Sears Parts, using your model number. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 20, 2010 | LG WM2277H Front Load Washer
2,263 people viewed this tip
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
