Tip & How-To about Zeagle Rapid Diver System - Buoyancy Compensators - Technical - Diving Gear
The Rapid Diver System
Lightweight Scuba System Goes From Tactical to Practical
RAPID DIVERâ„¢ is a lightweight, all-inclusive scuba system that mates a tank, regulator and buoyancy module to a uniform-fit, load-bearing harness. It was created in response to public safety and military needs for a universal fit, compact, versatile and easily deployed scuba system.
Mission requirements called for a system that is universal fit, could be stored in a small space, donned and activated quickly, and worn in situations such as helicopter and boat operations in which conventional scuba gear would prove too cumbersome and restrictive. Comfort was also of great importance, as some operations would require the user to wear the gear for extended periods of time while engaged in complex, task-loaded missions. With an overall weight of just 25 pounds, the Rapid Diver stores in a compact hand-carried pouch, and readies for use in less than a minute. It provides sufficient air duration for the average dive a 20 to 25 minutes at moderate depths. The Rapid Diver can go from duffel to dive in 15 seconds.
Though designed for professional use, many of the Rapid Diver's performance characteristics make it equally suited to a range of civilian applications. It is the preferred system for shore diving, due to its user-friendly design, universal fit capability and ease of transporting and storage. Persons who are unable to wear heavy conventional scuba gear, or who simply feel uncomfortable with the associated bulk and weight, appreciate the light overall weight and wearer comfort of Rapid Diver. In addition to a low overall weight, the Rapid Diver features a unique load-bearing harness that distributes the weight of the tank evenly over the diver's torso, making it well suited for difficult shore entries and is also beneficial for long walks to the water or water entry from ladders or small boats. Rapid Diver's small size allows it to be stowed aboard a boat, where it can be deployed for underwater boat maintenance, anchor checks, and fast response to emergencies such as a fouled prop or suspected hull damage.
Also unique to the Rapid Diver system is the ability to configure the rig for a wide variety of mission profiles. In it's simplest form, the Rapid Diver can be configured to become a PFD by removing the tank and life support system, beneficial in most boat operations (Tactical Swimmers Vest TSV). For extended dive profiles, the Rapid Diver can be configured with standard sized tanks (80 cu ft) mounted on the innovative back pad. If mission requirements call for an even longer diving profile, the Rapid Diver can be used in conjunction with surface supplied air or in a traditional side mount configuration. Other custom-configurable gas management options allow the user to configure the rig with a redundant air supply, and to use full-face scuba masks in conjunction with a gas switching block. To extend duration and stealth, a rebreather module which clips onto the existing Rapid Diver Tactical is in the works and will be made available for military applications.
Rapid Diver is a premium product and was created by dive equipment developer and long time diver, Christopher De Felice. The Rapid Diver is manufactured in the United States, constructed using materials selected for extreme durability and wear resistance.
For the latest information about the Rapid Diver system come and join us at the Official Rapid Diver Forum:
rapiddiver.board-directory.com
www.RapidDiver.com
Zeagle Rapid Diver System - Buoyancy Compensators - Technical - Diving Gear Logo
Guidelines to Scuba Regulator Purchase
The scuba regulator is employed in an open-circuit scuba set. Said scuba equipment reduces high air pressure conveyed by the diving cylinder to the first stage and feeds breathable gas to the diver through the second stage's mouthpiece. Also called pressure regulator or demand regulator, the scuba equipment is one of the essentials to diving that determines breathing quality and inhalation effort during the dive. But given the different types of regulators and the pertinent design of its first and second stage components, how should a neophyte diver - or even a seasoned diver at that, choose a scuba regulator that incorporates user adjustment and delivers a venturi-assisted air flow in its features? Consider your diving purpose and frequency. Better yet, take note of the following criteria to guide you in your purchase: 1. The Scuba Regulator's Mouthpiece. Check the specifications if the regulator is outfitted with a patented orthodontic mouthpiece. This implies that it is ergonomically-designed to accommodate an overbite or underbite by the human mouth. An ergonomic mouthpiece helps reduce fatigue in the mouth and jaw area, particularly in the cruise of lower depths and extended dives. 2. User Adjustment Settings. There are optimally-designed scuba regulators that are outfitted with adjustment levers to therefore allow divers to finetune valve settings in order to provide the least possible inhalation effort throughout the dive. One notable scuba equipment is the Aeris AT 400 Pro Regulator that is equipped with an adjustable second stage. 3. Weight of the Scuba Regulator. Visualize yourself on a dive and using just any other type of scuba regulator. Is the regulator bulky to considerably increase drag and cause jaw fatigue or is it buoyant enough for you to carry around with your mouth? Lightweight scuba regulators use polycarbonate thermoplastics for its housing to make the scuba equipment compact, sturdy and corrosion-resistant that makes them fit for extended use. 4. Nitrox Compatibility. This entails an ocular inspection of the cylinder tank (Nitrogen and Oxygen proportions) and scuba regulator (Nitrox compatibility) specifications. As a matter of convention, most regulators are suited for nitrox mixture use out of the box; containing the standard, maximum proportion of 40% Oxygen (in terms of volume) but then again, there are gas mixes supporting leaner proportions of oxygen such as the trimix. Therefore, check if the scuba regulator supports the gas mixture configured for your diving cylinder prior to purchase. 5. No-Contaminant Feature. As much as possible, choose a diving regulator that has been manufactured using Dry Valve Technology (DVT). DVT operates through an automatic valve that prevents contamination of the first stage mechanism to thus prevent regulator flooding and the entry of moisture or dust particles. This likely improves scuba regulator performance and extends its useful life. 6. Air-Sharing Feature. This feature often associated with octopus regulators (used as a spare demand valve or alternate second stage) will prove to be most helpful during diving emergencies such as a free flow or during diver rescues. High performance octopus regulators such as the Aeris Gyro Octopus Regulator are designed lightweight and with air-sharing feature, while sporting an inline swivel for convenience mounting and flexibility
Dec 01, 2008 | ACCO Brands Apollo Bio-Filter Moisture...
do I need a scuba regulator and if so, how do I know which one to buy?
"Because the scuba regulator is such a vital piece of gear many scuba divers choose to buy their own scuba regulator instead of renting one from the dive shop. When a scuba diver has used a few different scuba regulators, on numerous dives, he will notice that they all have slightly different ""action"" - some feel looser or tighter, some will deliver air more forcefully, others will have a slight ""suck"" to them. The goal of all regulators is the same: to deliver air on demand at ambient pressure. Comfort with a scuba regulator depends on how the diver breathes; which is different for everyone. Though a helpful clerk at the dive gear shop can recommend ""the best"" regulators, from the most respected manufacturers, in truth no one can tell you which regulator ""feels right"", except you. Sponsor Links [what's this?] As a novice scuba diver renting or borrowing equipment from a dive shop always take note of what scuba regulator you are using and whether you like how it feels. When you find the one which makes your breathing feel effortless remember its make and model. When you decide to buy your own scuba regulator you will know which one to get. When shopping for a scuba regulator here are some things to consider: See our choices for scuba regulators * Ergonomic design and easy to hold * A purge button which is easily pressed even when wearing 6mm neoprene gloves * External controls which let you make fine adjustments to air flow * Non-corroding metals like titanium or chromed brass * Diaphragm vs. piston mechanics. Many divers prefer diaphragm regulators for its smooth movement and its moving parts are less * Balanced vs. unbalanced regulators. Almost all regulators are balanced. Do not buy an unbalanced regulator. * Always buy new. Do not pick up a cheap second-hand regulator; it may be faulty or reconditioned * Look for a warranty * Swivel joints on the second stage offer improved ease of movement * Hose should be soft and flexible "
first and second scuba regulator
The scuba regulator has two parts: a 1st stage and a second stage connected by a hose. The 1st stage connects right to the tank; the 2nd stage is the contraption behind your mouthpiece. Both have an important function in regulating air flow throughout your scuba system.
603 people viewed this tip
Top Zeagle Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Zeagle Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
