Tip & How-To about Electric Electrical Supplies
Fishing electrical wire down a wall
I do a few measurements to determine where to drill holes,
in the attic I measure from the wall and locate top plate of wall to be fished
the bottom of the wall at the trim is where I need the wire to exit
so I attach a piece of chain to my wire
drop the wire straight down wall
use a retrieving magnet to fish wire out...
I use to try and hook a line and try and look in the hole for the wire?
although with the chain and magnet technique you can do this with your eyes closed, well almost, it just makes it easier!
after the wire is fished I can install....
hope this helps anyone wondering how this is done?
as always Be Safe, and if you are unfamiliar with the potential hazards of electricity, Please do Not attempt this.... Frederick Electrick Google
Electrical Supplies Logo
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
HOW FAR DOES THE CHUCK TRAVEL IN IT'S FULL MOVEMENT
This will all depend on your bit an your table setting. The chuck is easy to determine. Just measure the distance it travels with a tape measurer.
Jun 22, 2015 | Skil 3320-01-RT Factory-Reconditioned 10"...
I just fininsh a room in the attic and I want to put a baseboard electric heater. which is the best way to run the wire from the attice to basement? Thanks
Wow - You're looking at quite the job!! The wire needs to be protected inside the walls or at the least inside conduit along the outside of the house - but that wouldn't be too pretty. I suggest getting yourself an Electricians fishtape ( if you don't already have one ) and choose a point either inside a closet or in a visually hidden location you can drill through the floors and the walls to fish your romex through. If all walls are sheetrock, you may have to literally cut a channel into the wall ( use a good metal detector to find existing electric and plumbing so you can miss those ) , bury the wire, and backfill with plaster or sheetrock mud. Either way, have patience - it is a long road you're going down. The easiest way ( not the prettiest, or necessarily legal in your area ) is to run some conduit vertically along the outside of the building and fish your wire into it. Get some wiresnot to help reduce friction and simplify the pulling of the wire in the conduit.Punch your hole through the basement and attic walls and make sure you seal those holes real good with silicone. Check first with your local city and or county building code enforcement office for the legality of externally mounted conduit / wire.
Hope this helps!
Nov 10, 2010 | Heating & Cooling
I bought a used over the range microwave oven( kenmore) I would like to know how to install it knowing there is an opening to the roof. thank you
Most Kenmore microhoods use a 3" by 10" exhaust duct. Check for correct demensions. Make sure that the existing vent is this size or that you have room to adapt to this size. There should be a damper mounted to the top of the micro which will attach to the vent duct work. You will need an outlet in the cabinet above the micohood. This should be on a circuit of it's own. The microhood should have a wall plate for the back wall. I'm going to assume there are no templates available. Hold the wall plate against the back of the micro to determine the height placement in the opening. Most install centered under and against the cabinet above. Not all do, so this will confirm. Mount the wall plate to the existing wall studs with at least 1/4" by 2-1/2" lag bolts. Bore an 1-1/4" hole in the right rear corner of the cabinet above, about 2" out from the back of the cabinet and 2" in from the side, this is not a critical measurement, it is to pass the electric cord into the upper cabinet. There are two screws that support the front of the hood. I believe they are 1/4" by 3-1/2" long. If not included, check for size. The hardwae will have them, get flat washers to fit both also. Measure from the back of the micro to the mounting holes in the top of the micro, include the wall plate in this measurement, they'll be about 10" out from the back and about 1-1/2" in from the edge, near the front, but check that measurement, they vary. Drill 3/8" holes in the bottom of the cabinet at these locations. If doing this alone, best that you move the range out. It's nice to have a helper at lifting time. With the plate on the wall and the holes in the bottom of the cabinet, your ready. Put the 1/4" screws and someting to drive them in the upper cabinet, so they'll be available. Lift the micro into the opening with the front tilted downward, hook the back of it into the bottom of the wall plate, push the cord into the upper cabinet, tilt the front of the micro up until you can start the front support screws. Start both, don't let go of the micro until you are sure that both screws are started and will support the front weight. Once you're sure, tighten both screws all the way and connect the vent. Steel tape is best for sealing up any leaks. Power up the outlet, plug in the microhood and put in the popcorn. Get a good movie and enjoy in your accomplishment. Congrats. PS: Make sure the roof vent opens when the hood is turned on, I have seen them stuck shut from grease build-up.
Oct 22, 2009 | Microwave Ovens
Hood pins on a 1991 Pontiac Firebird
Find the point on the radiator support where the pins will be located.Be sure there isn't anything underneath to drill through.Measure from the fender to the center point of the hole location,and measure from the front fascia(edge where the front edge of the hood meets the body)to the center point of the hole location.Use these measurements to mark the hole on the hood.Repeat for the other side.MEASURE TWICE DRILL ONCE.
Sep 10, 2009 | 1991 Pontiac Firebird
707 people viewed this tip
Top Electrical Supplies Experts
ashburton
Steve
Mike Carew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
