Tip & How-To about Dryers
Dryer when start switch pressed no start but buzzes
I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
Dryers Logo
My interior lights come on at random, while parked and sometimes while driving. I noticed today that the alarm does not activate when this happens while it is parked and the interior lights are on.
Each door has a switch on the door opening that turns the light on when it is open, one of them is faulty or the door is not closing it.
May 21, 2015 | 2005 Mazda Tribute
Have ptdn600emwt dryer when pressing start button makes noise but does not run
Feb 27, 2015 | GE PTDN600EMWT Dryer
door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
304 people viewed this tip
Top Dryers Experts
