Tip & How-To about Stairmaster 4000PT Stepper
Mechanical System Troubleshooting for Stairmaster 4000PT Stepper
  1. Remove the side covers. WARNING: TO REDUCE THE RISK OF INJURY, DO NOT OPERATE THE MACHINE WHILE THE COVERS ARE REMOVED. DO NOT DEPRESS OR RAISE THE PEDALS WHILE ANYONE'S HANDS ARE INSIDE THE MACHINE.
  2. Remove the Poly-V belt and inspect the belt for cracks, fraying or any other unusual or excessive wear.
  3. Spin the alternator pulley to check the bearings. Replace the alternator if any clicking or grinding noises are heard.
  4. Inspect the alternator pulley for wear.
  5. Tighten the transmission pulley set screw to the flat side of the transmission output shaft.
  6. Remove the drive chain and inspect the chain for frozen links. Replace a chain with frozen links.
  7. Tighten the transmission drive sprocket set screw to the keyway in the transmission input shaft.
  8. Spin the transmission drive sprocket input 1 complete revolution. The transmission pulley output should turn 19 revolutions. Replace the transmission if any clicking or grinding noises are heard during rotation or the drive ratio is not 19 to 1.
  9. Remove the step chains and return springs from the main frame of the machine.
  10. Inspect the step chains for frozen links and the springs for corrosion. Replace a chain with frozen links and replace a corroded spring.
  11. Make sure that the step chain connection points pivot freely and have no vertical play.
  12. Remove the pedals, pedal arms, and leveling arms and lubricate according to the maintenance section of the manual.
  13. Verify that the clutch sprockets of the hub assembly spin freely in the forward direction and lock in the reverse direction.
  14. Inspect the hub assembly for wear. The drive shaft sprocket should not move up and down or side to side.
  15. Clean and lubricate the drive and step chains with 30W motor oil.
  16. Reinstall all parts, ensuring the proper tension of the Poly-V belt and the drive chain.
Stairmaster Mechanical System Troubleshooting for 4000PT
Stairmaster 4000PT Stepper Logo
Where are the air bag sensors on a 2000 Lincoln towncar
Sensor - Front Crash Removal
WARNING: Vehicle sensor orientation is critical for proper operation. If a vehicle equipped with an air bag supplemental restraint system (SRS) is involved in a collision, inspect the sensor mounting bracket and wiring pigtail for deformation. Replace and properly position the sensor or any other damaged supplemental restraint system (SRS) components whether or not the air bag is deployed.
WARNING: Always wear safety glasses when repairing an air bag supplemental restraint system (SRS) vehicle and when handling an air bag module. This will reduce the risk of injury in the event of an accidental deployment.
WARNING: To reduce the risk of personal injury, do not use any memory saver devices.
NOTE: The air bag warning lamp illuminates when the RCM fuse is removed and the ignition switch is ON. This is normal operation and does not indicate a supplemental restraint system (SRS) fault.
NOTE: The SRS must be fully operational and free of faults before releasing the vehicle to the customer.
NOTE: Repair is made by installing a new part only. If the new part does not correct the condition, install the original part and perform the diagnostic procedure again.
  1. Depower the system. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in this section.
  1. Remove the radiator upper sight shield (8C291).
  1. Remove the air bag sensor.
    1. Disconnect the air bag sensor electrical connector.
    1. Remove the three screws.
    2. SECTION 501-20B: Supplemental Restraint System 2000 Town Car Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/10/2004 Sensor - Side Crash Removal
      WARNING: Vehicle sensor orientation is critical for proper system operation. If a vehicle equipped with an air bag supplemental restraint system (SRS) is involved in a collision, inspect the sensor mounting bracket and wiring pigtail for deformation. Replace and properly position the sensor or any other damaged supplemental restraint system (SRS) components whether or not the air bag is deployed.
      NOTE: Left side is shown, right side is similar.
      NOTE: The side crash sensors are located under the carpet beneath the front seats.
      1. Position the seat to gain access to all fasteners.
      1. Remove the front seat. For additional information, refer to Section 501-10 .
      1. Remove the safety belt anchor bolt cover.
      1. Remove the bolt and the safety belt anchor.
      1. Remove the front and rear door scuff plates.
      1. Remove the lower B-pillar trim panel.
      1. Remove the carpet to access the side crash sensor.
      1. Remove the side crash sensor.
        1. Remove the retaining bolts and position the side crash sensor in order to disconnect the electrical connector.
        1. Disconnect the electrical connector.
        1. Remove the side crash sensor and bracket.
Dec 16, 2015 | 2000 Lincoln Town Car
where is the switch to disable the passenger airbag on a 2003 ford taurus
Depowering Procedure
restraint system (SF3) vehicle and when handling an air bag module. This will reduce
WARNING: Never probe the connectors on the airbag module. Doing so can result in
air bag deployment, which can result in personal injury.
devices.
NOTE: Ifa seat equipped with a seat mounted side airbag and or a safety belt
pretensioner (if equipped) system is being serviced, the supplemental restraint system
(SES) must be depowered.
to the customer
1. Turn all vehicle accessories OFF.
2. Turn the ignition switch to OFF.
3. At the central junction box (Cm), located below the LH side of the instrument panel,
remove the cover and the restraints control module (RCM) fuse F223 (lOA) from
the CTh. For additional information, refer to the Wiring Diagram Manual.
4. Turn the ignition ON and visually monitor the air bag indicator for at least 30
seconds. The air bag indicator will remain lit continuously (no flashing) if the correct
ROsI fuse has been removed, If the air bag indicator does not remain lit
continuously, remove the correct RCM fuse before proceeding
5. Turn the ignition switch to OFF.
6. WARNING: To avoid accidental deployment and possible personal injury, the
backup power supply must be depleted before repairing or replacing any front or
side air bag supplemental restraint system (SRS) components and before set-ricing,
replacing, adjusting or striking components near the front or side air bag sensors,
such as doors, instrument panel, console, door latches, strikers, seats and hood
latches.
To deplete the backup power supply energy, disconnect the battery ground cable
and wait at least one minute. Be sure to disconnect auxiliary batteries and power
supplies (if equipped).
Disconnect the battery ground cable and wait at least one minute.
Repoweri.ng Procedure
1. WARNING: The restraint system diagnostic tool is for restraint system service
only. Remove from vehicle prior to road use. Failure to remove could result in
injury and possible violation of vehicle safety standards.
Make sure all restraint system diagnostic tool(s) that may have been installed during
the repair have been removed from the vehicle and all SRS components are
connected.
2. Turn the ignition switch from OFF to ON.
3. Install the ROsI fuse F2.23 (lOA) to the DB and install the cover.
4. WARNING: Be sure that nobody is in the vehicle and that there is nothing
blocking or set in front of any air bag module when the battery ground cable is
connected.
Connect the battery ground cable.
5. Prove out the supplemental restraint system (SRS) as follows:
Turn the ignition key from ON to OFF. Wait 10 seconds, then turn the key back to
ON and visually monitor the air bag indicator with the air bag modules installed. The
air bag indicator will light continuously for approximately six seconds and then turn
off. If an air bag supplemental restraint system (SF3) fault is present, the air bag
indicator will:
- failto light.
- remain lit continuously.
- flash.
The flashing might not occur until approximately 30 seconds after the ignition switch
has been turned from the OFF to the ON position. This is the time required for the
restraints control module (RCM) to complete the testing of the SRS. if the air bag
indicator is inoperative and a SRS fault exists, a chime will sound in a pattern of 5
sets of 5 beeps. If this occurs, the air bag indicator and any SRS fault discovered
must be diagnosed and repaired.
Jan 12, 2011 | 2003 Ford Taurus
now to install igintion switch
Removal & Installation The ignition switch or warning switch can be replaced without removing the steering lock assembly. The ignition switch is on the back of the assembly and the warning switch on the side.
  1. Disconnect the negative battery cable and insulate the terminal end.
CAUTION The air bag system must be disarmed before removing the steering wheel. Failure to do so may cause accidental deployment, property damage or personal injury.
  1. Remove the steering wheel and the steering column upper and lower covers.
  2. Remove the spiral cable assembly.
View of the steering lock and ignition switch assembly
  1. Remove the combination switch from the steering column.
  2. Remove steering column support nuts and lower the steering column.
  3. Disconnect the ignition switch wiring and interlock cable (if equipped).
  4. Remove the bolts that secure the steering lock and remove steering lock assembly.
To install:
  1. Install the steering lock assembly and secure with new shear type bolts.
  2. Connect the ignition switch wiring harness and the interlock cable.
  3. Raise the steering column and secure with mounting nuts.
  4. Install the spiral cable assembly.
  5. Install the combination switch, steering column covers, and the steering wheel.
  6. Connect the negative battery cable and enable the air bag system.
May 23, 2010 | 1997 Nissan Maxima
front headrest, ford focus
Seat Backrest — Front adobe.gif Printable View (404 KB) Disassembly
All vehicles
ani_caut.gif WARNING: Always wear safety glasses when repairing an air bag supplemental restraint system (SRS) vehicle and when handling an air bag module. This will reduce the risk of injury in the event of an accidental deployment.
ani_caut.gif WARNING: Never probe the connectors on the air bag module. Doing so can result in air bag deployment, which can result in personal injury.
ani_caut.gif WARNING: Front seat back trim covers installed on seats equipped with side air bags cannot be repaired, they are to be replaced. Cleaning is permissible.
ani_caut.gif WARNING: To reduce the risk of personal injury, do not use any memory saver devices.
NOTE: If a seat equipped with a seat mounted side air bag and/or a safety belt pretensioner (if equipped) system is being serviced, the supplemental restraint system (SRS) must be depowered.
  1. Depower the SRS. For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in the General Procedures portion of Section 501-20B.
  1. Remove the head restraint.
  1. Remove the head restraint guides.
    • Using a suitable screwdriver, depress the locking tang.
May 31, 2009 | 2004 Ford Focus
328 people viewed this tip
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
