Tip & How-To about Stairmaster StairClimber SC916 Stepper
Preventive Maintenance for SC916 Stepper
This video is covers preventive maintenance on your Stairmaster SC916 Stepper. Following a good preventive maintenance schedule will reduce equipment down times and repair costs. Due to the workout your equipment gets from use, they can become dirty over time.
Inspect the heart rate grips (if equipped) and make sure there is no accumulation of sweat on or around the contacts. A non-abrasive cleaner can be used on the contact heart rate grips daily.
Inspect all the shrouds and ensure they are securely fastened and no cracks have developed. Use of abrasive cleaners can create cracks in the shrouds or cause them to become brittle.
Inspect the cup holder shroud. Make sure there have been no holes drilled into the shroud for the purpose of allowing sweat to drain and preventing accumulation. The proper method of dealing with the sweat accumulation in the cup holder shroud is regular cleaning of the area.
Once you've made all the shroud inspections, step up onto the pedals. Feel the motion of the unit and verify smooth operation. Listen for irregular noises. A good maintenance routine allows you to recognize how a unit in good operating condition should feel and sound.
Next, inspect the step chains. The links of the chain should move freely. The chains should be lubricated on a 3 month basis with 30w motor oil.
Inspect the pedal hardware. Each step the user takes, there is movement of the pedal hardware. Ensure that all the snap rings are secure to their shafts and none are working free. If a snap ring is not secure, it's possible that damage to the pedal can occur or it could fall off during exercise and possible injury could occur.
These are the main points for preventive maintenance.
http://www.sportsmith.net/video-player.aspx?did=8BB04E2A-F009-42FF-9585-2F0CCC98D8D0
Stairmaster StairClimber SC916 Stepper Logo
I have a stairmaster 4400 and every time I get on and try to select a workout it says config rqrd and if I push the clear button it turns off
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Feb 26, 2014 | Stairmaster 4400 PT Stair Stepper
I notice lately when on my personal climber hear squeaking noise on bottom of chain. Can I use WD 40 oil?d oil 40 to
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The manufacturer actually suggests using a 30W motor oil to lubricate the chains.
Preventive Maintenance Video for Stairmaster Stepper SC916
This video is covers preventive maintenance on your Stairmaster SC916 Stepper. Following a good preventive maintenance schedule will reduce equipment down times and repair costs.Due to the workout your equipment gets from use, they can become dirty over time.
Nov 18, 2013 | Stairmaster Exercise & Fitness
configure RQRD
Corrective Action
Mar 25, 2013 | Stairmaster 4600PT Stepper
My stairmaster 4400 PT shows "config rqrd" How do
Corrective Action
Oct 14, 2011 | Stairmaster 4400 PT Stair Stepper
371 people viewed this tip
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
