Tip & How-To about Exercise & Fitness
Recommended Tools for an Indoor Cycling Tool Box
Video about the Recommended Tools for an Indoor Cycle Tool Box
  • This video will show what tools and products you will want to have in your tool box if you are working on indoor cycles
  • The tool kit shown in this video is a kit that you can buy from Sportsmith that has a lot of the tools you will need
    • They include but are not limited to:
      • Cotterless Crank Arm Extractor
      • 8MM Hex Wrench (for crank arm bolt removal on some cycles)
      • Six Inch Adjustable Wrench
      • Phillips and Flat head Screwdriver with Magnetic Tip (which can be quite handy in the field)
      • 14mm & 15mm Pedal Wrench (for installing and removing pedals)
      • Chain Break Tool
      • Chain Whip Tool
      • Bottom Bracket Tool
        • Something you might want to add to the kit is a 5/16"-24 x 2" bolt and several washers that you can use to install the tool on to the bottom bracket with. Then use another tool to loosen the bottom bracket by turning the bottom bracket tool
      • Set of Hex Wrenches
  • Sometimes you may find that you cannot get enough torque or the right size from the set of hex wrenches in the pre-packaged tool kit, so it's a good idea to have a set of the bits that will work with a 3/8" drive ratchet or for use with your torque wrench when setting torque on things
  • You may also want to include an ISIS style bottom bracket tool in your toolbox, which you can also use the bolt and washers with if needed
  • Some of the other tools you will need to have in your tool box:
    • Lock Ring Tool
    • Torque Wrench
      • We show both a click style and a needle and beam style torque wrench in the video
      • Either one will work, just be sure to consult the manual to get the torque specs for whatever you are setting torque on
    • A rubber mallet is also handy if something is locked up or jammed
    • A good pair of pliers and a set of locking pliers are also helpful at times
    • A chisel is sometimes needed to use with the rubber mallet to turn a rusty nut or bolt or to push out the pressed in bottom bracket bearings
    • You will want a wire brush for roughing up leather brake pads before applying oil or for removing rust from something
  • Some of the products we use and recommend are:
    • Stainless Steel Polish
    • Quick Shot Grease- from Schwinn- synthetic based, multi-service, non-melting waterproof grease
    • Tri-flow Penetrating Lube- loosens rusted parts, frees sticky mechanisms, washes away dirt, corrosion and contaminants
    • Clean Ride- use on cycle chains to prevent buildup of debris
      • Debris forms but flakes off over time instead of building up
    • Thread Locker- probably the most valuable product in the box- use on nuts and bolts or even bottom brackets that repeatedly come loose
    • 3-n-1 Oil- lubricates, stops rust, and protects metal
      • Used on leather brake pads to extend life
  • That pretty much covers what you should carry in your tool box to service indoor cycles
Video about Recommended Tools for an Indoor Cycle Tool Box
Exercise & Fitness Logo
Where to purchase no 858-002 tool box
I looked at a few web sites - what they have is " this product no longer vailable" !
Jun 07, 2014 | Plano Molding Co No.858-002 20x11x13 4Draw...
corrupted files from usb, how do i recover?
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Sep 17, 2012 | Data Recovery Software IdeaPad A2109 ...
how do i use acer crystsl eye to video chat on msn messenger
hi
if you open msn page
then click on the name of the person that you want to video with
go up to tools if its there
if its not go to
bottom right hand side of screen where you would normally text
and you should see an arrow which when highlighted says
( Show more commands )
click on it and go down to and click on Show the menu bar
then the tools option should be in the top of the box of the person that you are in chat/video or text with
anyway click tools
then click on set up audio and video devices
then it should open up the audio/video/webcam set up box
and if there is a problem with either audio or webcam it will tell you then
good luck
also you may find it in your programs
start
programs
crystal eye webcam
Mar 12, 2011 | Acer Aspire 5610-4648 Notebook
i blew my transmission doing wayy too many burnouts and i have another transmission and everything i need im just not sure what to do to put it in
YOU NEED SUPPORT ENGINE WITH ENGINE SLING TOOL VW - 10 222A OR EQUIVALENT FOR VW CYLINDER HEAD. YOU NEED TRANSMISSION JACK.YOU NEED TOOL BOX WITH 1/4 3/8 1/2 RATCHETS AND YOU NEED ALL STANDARD AND METRIC SOCKETS ALSO OPEN BOX END WRENCHES..IF YOU DONT HAVE ANY TOOLS BE CHEAPER TO GET A TRANSMISSION SHOP TO DO THE JOB.IF YOU GOT THE TOOLS AND ENGINE SUPPORT TOOL ALL YOU NEED IS A REPAIR MANUAL IT WILL HELP YOU QUICKER IT WILL SHOW AND TELL YOU HOW TO REMOVE TRANSMISSION.
Nov 25, 2010 | 1999 Volkswagen Jetta
problem
If you have any problem to view a video, such as in Youtube.com, try to use more than one browser, such as Mozilla Firefox, Internet Explorer and Google Chrome. Generally clear the browsing data will solve this issue. follow these steps to clear browsing data. Internet Explorer Click on Tools and select Delete Browsing History or press Ctrl+Shift+Del. From the prompt, check on the boxes of data types you want to erase and click the Delete button. For faster browsing experience while opening the sites you frequently visit, it is recommended to check the box of Preserve Favorite Website Data. Firefox Select Tools on the top menu and click Clear Private Data. You can summon this command by pressing Ctrl+Shift+Del. Check on the items you want to erase including browsing history, cache, cookies, saved password and authenticated sessions. Google Chrome Click on the Tool icon and select Clear Browsing Data.
Jun 07, 2009 | YouTube Videos
287 people viewed this tip
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
