Tip & How-To about Tablets & eReaders
Reinstall or Format Android OS on Tablet PC
Process of reinstalling android os on Tablet PC is called Flashing.
Reasons to flash the Tablet PC:-
i- OS corrupt
ii- Tablet get stuck at boot menu
iii- Hang
iv- Slow processing
v- Tablet getting on/off automatically
vi- Application not responding
Re install Android OS on Tablet PC
Tablets & eReaders Logo
why will my tablet not stay on?
if you have done somerooting, your tablet is probably bricked. no warranty can be claimed. but, if it goes out suddenly just like it is. it may be you system OS is corrupted. try flashing a stock Rom (original one from the manufacturer's website)
Dec 07, 2015 | TabletExpress Dragon Touch 7 Black Dual...
Hisense sero 7 is not chargeing what do i do
Android Tablet not charging
Reasons:-
1- Set stuck
2- Sleep of death
3- Due to Dust
4- Power button broken
5- Carbon
6- Dry Shouldering
7- Corrupt OS
8- Faulty Charger
9- Charging connector Damaged
Solution:-
Android Tablet Not Turning ON 15 Reasons Solution
Feb 19, 2015 | Tablets & eReaders
bauhn 9.7 3g tablet will not start up
Many things can cause a tablet fail to start. A damaged battery is one. It can also be due to a burned display. More often than not, it is due to OS having been corrupted. If the tablet can start with the charger connected, chances are the battery is no good and had to be replaced. For defective display, you can try connecting the tablet to a digital TV through the HDMI port. You may see something if the tablet is working but its display is defective. If the OS is corrupted, you will have to reflash its ROM with the right version using a computer. This process is a little too technical for novice. Get help from an expert. Remember, flashing will void your warranty.
There are other less likely causes for startup problem. If it's hardware issue, you are doomed.
Jan 12, 2015 | Tablets & eReaders
can i reinstall os from pc
No, your android tablet cannot take an OS off a PC.
Try removing the battery for a minute, see if that un-sticks it.
Sep 11, 2014 | Apex TMAX Blue 8GB 9" Android 4.2 1.6 GHz,...
rca tablet will not boot
Here are some common reasons tablets wont boot:
- SD card full or corrupted
Remove SD card (if you have one in your tablet) and try to boot
- Corrupted OS / Application / Data
Try a reset
If your tablet is rooted, you can often boot with the bootloader and wipe the application data.
re-flashing the firmware of the tablet works 99% of the time.
Jan 30, 2014 | Tablets & eReaders
415 people viewed this tip
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
