Tip & How-To about Konica Minolta Office Equipment & Supplies
Code C0200 for the Minolta EP Model Series Machine.
Below the drum is an assemble that houses two very fine gold plated wires. They do two things since the paper goes above these two wires and below the drum. The first wire transfers the image on to the paper from the drum, the second one prevents the paper from sticking to the drum. One or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs when replacing them. You can attempt to clean them with a pencil eraser, but you must BE GENTLE, stroke toward the spring. Also clean the assemble itself, with a rag be CAREFUL of the wire if you are doing it with them in installed. If that does not work you might have bad ends on the assy. After a while/years the plastic breakdowns and allows the voltage to go to ground. The wires carry around 2000 volts during the copy process. None during power off :) Open and close the front door to resets the code. If you need the parts try online ask for Corona wires or transfer/separation wires for you model machine.
Knica minolta Ep 4000 C 0200
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wires carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Oct 11, 2015 | Minolta Office Equipment & Supplies
co2oo is my machines
Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. if that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off.:) Open close the front door resets the code.
Aug 26, 2013 | Minolta EP4000/5000 CS/PRO Copier
bagaimana mengartikan kode error c0200
Sir/Mam, Below the drum is an assemble that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first wire transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Aug 09, 2013 | Minolta EP4000/5000 CS/PRO Copier
di550 light printing
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. use a eraser end gentle I mean gentle clean them. release front lever then push down and pull out transfer/separation assy. remove the guides clean wires, again be gentle, has the drum been replaced, does this happen with printing or copying if only copying clean the mirrors below the big glass, be gentle can use Windex, use of paper towel don't leave any little paper particles
Jun 24, 2012 | Minolta Di550 B&W Laser Printer
c0200 on develop
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first wire transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
web site for parts
try below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 11, 2011 | Minolta EP1083 CS/PRO Copier
1,644 people viewed this tip
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
