Tip & How-To about Office Equipment & Supplies
How to Clear the Minolta EP/Di Model C-0070 Codes
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom an toner will go everywhere. Then close the toner cover/front door and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one. The KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If this procedure does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad, worse case the control board is bad that control the motor.
CS pro Minolta 500 code C071?
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
May 18, 2016 | Minolta Office Equipment & Supplies
manolta 5000 error 70
Power off the machine remove the toner bottle (BE CAREFUL hole in the bottle might be on the bottom then you will be spilling toner everywhere with. With bottle out turn on the machine if code shows open close the front door. let the machine do its thing when the machine ask for toner place the bottle inside it correctly.. If the nub on the bottle is damaged get a new one the nubs are how the copier grabs the bottle to turn it. If the code comes back then either the sensor is bad or the Toner bottle motor is bad and or the motor accurator All enclosed to the right of the bottle front end.
Jan 08, 2014 | Minolta EP4000/5000 CS/PRO Copier
code error c0700
Open close the front door. If that does not work , power off the machine, remove the toner bottle, be careful if the hole is on the bottom when you pull it out toner is going to go everywhere. With bottle out and front door closed turn on the machine. Let it go through its normal warm up. If the code appears open close front door. When the machine asks for toner install the bottle correctly, if the nubs on the bottle are damage get a new bottle those nubs are what the toner bottle motor uses to turn the bottle. If the code still comes back you need either a new motor/sensor/or accurator worse case a new control board.
Dec 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
my photocopy machine shows code C0070
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Reset open close front door WHAT MODEL IS THIS MACHINE?
May 24, 2012 | Minolta Office Equipment & Supplies
DI-152 C0070
J, Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Jul 21, 2011 | Minolta Di152 Laser Printer
875 people viewed this tip
k24674
