Tip & How-To about Denon DN-X1500S DN-X 1500 S DJ Mixer
DISASSEMBLING AND CIRCUIT DIAGRAM
DENON DN-X300 DJ MIXER
DISASSEMBLE PROCEDURE
1. Top Panel
(1) Pull out the Knobs from the Top Panel.
(2) Remove the 6 screws attaching the Top Panel.
(3) Pull up the Front Panel.
for more check the link bellow use the search tab to find DENON DN-X300
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Denon DN-X1500S DN-X 1500 S DJ Mixer Logo
denon dn-x300
Greetings
can you explain more?
or just the sliding fader is not working?
if the sliding fader is not working u need to change the sliding part
REF: SLIDE VR(RA45D2-211-15D1-R0B50K)
its 50K Ohm slider.
sometimes the material inside the slider ends fast due to activity.
hope this helps
Kind Regards from Audio-adviser.com
Feb 15, 2014 | Denon Dnx300 3-Channel DJ Mixer System
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
522 people viewed this tip
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
