Tip & How-To about Microsoft Xbox 360 Console
Xbox360 Slim 12 volt fan mod, to keep your system cool all the time.
Step By Step Tutorial
1. Remove case of the xbox 360
2. Remove DVD drive and Harddrive holder inside the console
3. Unplug the fan
4. Unhook the small tab holding the blue wire out of the white male connector
5. Fold the wire back and tap it to the rest of the wires
6. Reason for doing this incase you decide you want to change it back to normal fan speed
7. Tape the wire back to the other wires covering the metal end of the wire so it doen't short out on anythign else in the console
8. Plug the fan wires back in to the console
9. Test by powering it up
10. reassemble the console and you have fully succeded in a simple 12volt fan mod with no soldering required.
http://m.youtube.com/watch?v=4wGnFW40XMw
Microsoft Xbox 360 Console Logo
I have taken this xbox apart once before but did not get very far. What type of tools are necessary to repair this type of Xbox 360? I would also like to update the CD/DVD drive on it. Any hints or ti
Most of this can be taken apart with a screwdriver . The case is a little tricky. You will notice from the side...where the case is split, there are tabs on the inside that you need to press. I poked a small screwdriver through the vent holes to press them and get the box apart.
Oct 04, 2012 | Video Game Consoles & Games
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
forgot code and backup question
Complete Xbox 360 Backup Tutorial
PORTANT NOTE:
This tutorial is outdated and no longer used.. This tutorial has only been left here for archive purposes. If you require further assistance please try our VIP ONLY forums.
Alright guys, I thought that there weren’t enough decent tutorials/guides for making backups of your Xbox 360 games, so I decided to put one together myself. I figured that after burning 13 DVD+R DL coasters that I’d be a good guy and help other people form making the same mistake, so here goes.
Required Items
Before we start lets see what we all need:
1) A DVD-drive which can be easily taken apart
2) Your original xbox360 game
3) Data/Movie DVD which is at least 8 gigabyte in size
4) Philips screwdriver to open your DVD-drive
5) Last but not least, some patience
Required Software
1) WxRipper can be found in the 360-hq Downloads area here
2) XBOX360 SS Merger v1.6 here
Table of Contents
- Part 1: Creating the image.
- Part 2: Inserting the SS.bin.
- Part 3: Burning the image successfully.
ART 1 - Creating the Image
1. Take your DVD-drive apart: First of all we need to access the laser unit of our DVD-drive, this can usually be done by removing the screws which holds it casing! You will need to figure out yourself on how to do this for your own DVD-drive .... Read More >>
Jun 25, 2010 | Microsoft Xbox 360 Console
my xbox 360 says play dvd when i have a xbox 360 game in the console i bought it used but it didnt start doing it for a few weeks i need to know if i have to buy a new xbox or if i can fix it myself
Yes you can. provided you have the right tool and
info .you need to install a new laser . Find a tutorial on
how to take your unit apart on line . unplug and remove the drive
find out what drive you have ,it's on a label on
top the drive buy a laser from (riches PSX repair) when
you get the laser take a 30 watt soldering Iron with some
solder braid you can buy at radio shack and remove the
anti static solder dot on the laser then goto (riches PSX repair)
and follow the on line instructions and that should get up
and running again
if you have any questions just ask.
Rob
Nov 22, 2009 | Microsoft Xbox 360 Console
rock band 2 wont play my songs
Hi Sir =)
I'm Glad To Help You ^^
PORTANT NOTE:
Required Items
Required Software
Table of Contents
Apr 30, 2009 | Microsoft Xbox 360 Console
1,055 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
