Tip & How-To about Philips Televison & Video
INITIALIZING AND POWER SUPPLY CIRCUIT
PHILIPS HTS3251B/F7 - HTS3051BV/F7
HOW TO INITIALIZE THE BLU-RAY DISC HOME THEATER
[HTS3251B/F7]
To put the program back at the factory-default, initialize the BD player as the following procedure.
Note: By initializing, network is reset to disconnected state and "Network Service Disclaimer" appears on the screen.
1. Turn the power on.
2. Remove the disc on the tray and close the tray.
3. Press [1], [2], [3], [4], and [INFO] buttons on the remote control unit in that order. (All VFD lights)
4. Press [ STOP ] button on the remote control unit.
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Televison & Video Logo
My Philips HTS3541/f7 5.1 will not read blu rays or dvds how can this be corrected?
I think if you try a CD disc, you will find that disc will play. The Optical Pickup(laser) has worn out of specification. There are actually 3 lasers in the unit; a CD, DVD and Blu Ray lasers. They are all use different wavelengths of light, so one laser cannot cover all 3 wavelengths. Unfortunately, you will need a new pickup. Again, try the CD. I'm 90% sure it will play fine, unless the pickup is covered in dust(like my house :-(. If you would like more information, or would like to inquire about having your Philips repaired, please visit my website at audioserviceclinic.com. Thank you.
Dec 29, 2014 | Philips HTS3541/F7 - 5.1-Channel Blu-ray...
Unlock region on Philips HTS 3541/F7?
Unlock code for Philips HTS3541
1. Press Home
2. Press on R/C 8 6 8 9 3 1 0 (the 0 being multi-region)
Sep 13, 2012 | Philips HTS3541/F7 - 5.1-Channel Blu-ray...
I'm not getting any sound from my speakers.It shows them off.how do I turn them back on?
It might be going to the HDMI instead.
See Page 59 of the manual. Set "Audio Output" to "Speakers" in the settings menu.
See page 49.
Jun 27, 2011 | Philips HTS3251B/F7 Theater System
I just purchased a Philips HTS5580w/F7 home theatre. It is stated as being 3D ready but requires a software update. I cannot find the update for this model on Philips website
There is no software update as it is already able to play BluRay 3D as detailed in the Manual.
Before you start, make sure that:
• your TV is a 3D TV, and is connected
to your home theater through HDMI,
• your disc is a Blu-ray 3D disc, and
• you have 3D glasses that are
compatible with your 3D TV.
or the 'Fault' could be that the 3D is turned off
From Page 18 of the Manual
Play 3D discs in 2D
1 Press ( Home ).
2 Select [Setup] > [Video] > [Blu-ray 3D
video] > [Off] .
3 Press OK .
4 Play your Blu-ray 3D disc.
» The 3D video is displayed in 2D.
If it is selected as Off then obviously turn in On.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Philips HTS5580W/F7 Theater System
I have a Philips Home Theater model HTS3051BV/F7 C and I need to change for DVD region free or for DVD region 4, but I have not get procedure for this model. Can you help me please?
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Feb 14, 2011 | Philips HTS3051B/F7 Theater System
1,241 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
