Tip & How-To about Microsoft Windows Vista Ultimate Edition
Fixing Errors On Your PC for Windows Vista,7,8 and 8.1
I'm only going to show those interested how to run chkdsk (check disk) and fix errors, there are other commands mostly you'll just want to run this command. Click the Start button in the Search box, type command prompt in the list of results, right-click Command Prompt, and then click Run as administrator. In the command prompt, type in the following command chkdsk C: /F . Only type what is in bold, what this is going to do is check the drive for error and fix those errors. If the drive isn't locked it will bring up a message asking to scan the drive on the next restart click yes, if the drive is locked it will start scanning automatically. This depending on how large your hard drive is can take some time or not, be patient because this usually always fixes issues people are having that call me, other times I have to look at their PCs. Hope this helps you out.
Microsoft Windows Vista Ultimate Edition Logo
windows can't recognize
You need to run chkdsk......
How to run Chkdsk
Notes
Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer
Double-click My Computer, and then right-click the hard disk that you want to check.
Click Properties, and then click Tools.
Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
To run Chkdsk in read-only mode, click Start.
To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Exit code Description
0 No errors were found.
1 Errors were found and fixed.
2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified.
3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
Jun 30, 2012 | Western Digital Caviar Computers &...
igxprd32 error
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 13, 2012 | Computers & Internet
blue screen with error
You'll need a system repair disk or operating system disk to fix this problem. Put the disk in the cd drive and boot from it. You want to get to a dos command prompt (black screen with white letters) so that you can type in the following command: chkdsk /r
Check Disk will run well over an hour so be patient. You will even see the percentage of completion going from high to low but that is normal. Just let it run to completion then reboot.
In windows xp you get to the command prompt by doing a repair when you see the options come up from the system disk.
In vista you get there from the recovery console and you will see the dos command box at the bottom
If Check Disk does not solve your problem you'll need to reinstall windows. You can do a repair install which will preserve your docs, music, pictures and videos. A clean install will wipe out everything.
Also System Recovery wipes out everything and sets your computer back to the state it was when you first purchased it.
Mar 22, 2012 | Computers & Internet
upon connecting the samsung G2 to my laptop, it says "needs formatting" but when click the format disk option it says "disk can not be formatted'
Many errors in Windows are caused by corrupt files. Those files could have become corrupt because of errors on your hard drive. The Check Disk tool checks for errors and attempts to fix any it finds.
Warning: Use Check Disk at your own risk. On rare occasions I've experienced problems when using check disk in Windows Vista. Here are a few things to watch out for:
If you run check disk and your computer has to be restarted to scan your computer and your computer hangs at a black screen when it boots up, do the following: Turn the computer off and back on and immediately start pressing F8 on your keyboard repeatedly. A black screen with different boot options will appear. Select to use the Last known good configuration (advanced) boot option.
Never stop check disk once it has started. It could take hours to days to scan your hard drive depending on its size. How-to Use Check Disk Using the Graphical User Interface (GUI)
Open the Start Menu and click Computer. Right-click the drive you want to perform a check disk on and select Properties. Click the Tools tab in the drive Properties window.
Click Check Now under error checking. To perform a complete check of your hard drive for errors check off both options in the check disk window that pops up.
Click the Start button to start the process. If you are trying to check a hard drive that has open files you'll get a message similar to the one shown below.
Click Schedule disk check. Disk check can't check a hard drive that has open files. Your computer will reboot and check the disk before Windows Vista boots up. If you want to cancel the scheduled disk check for any reason, check out this guide.
Using the Command Line Interface
Check Disk can also be run using the command line (DOS) prompt.
Open the command prompt with administrative privileges by typing cmd in the search box in the Start Menu and right-click cmd.exe in the search results and then select Run as Administrator. Type chkdsk followed by one or a combination of switches listed below in the command prompt. If you run the check disk (chkdsk) command from the command prompt by typing just chkdsk check disk will run in read only mode. All it does is check for errors. It will not fix any errors it finds unless told to do so. This is done by adding switches when typing chkdsk in the command prompt.
A switch looks something like chkdsk /F. Notice the switch /F after the chkdsk command.
Below is a list of most of the switches used with the check disk command. You can use one or a combination of switches with the check disk command.
D: If you want check disk to scan a drive other than the C: drive, add the drive letter after chkdsk to tell it to scan that drive. If the drive is called X: on your computer it would look like chkdsk X:.
/F: The /F switch is the most common of the chkdsk switches. It tells chkdsk to fix any errors it finds. Chkdsk can't fix errors on a disk that has open files. If chkdsk asks you if you want to check the drive next time Windows Vista boots or dismount the drive choose to check the drive next time Windows Vista boots. Never choose to dismount the drive. That option should only be used by a professional.
/R: The /R switch tells chkdsk to attempt to recover any bad sectors of the hard drive if any are found. A bad sector is a spot on the hard drive that can't hold saved data anymore.
/I: The /I switch tells chkdsk to perform a less detailed but faster disk check.
/C: The /C switch tells chkdsk to skip the checking of cycles within a folder structure which reduces the scan time. Don't ask me what this means.
An example of an exhaustive disk check using the command line interface is:
chkdsk D: /F /R
The check disk command shown above will fix any errors it finds and also attempt to recover bad sectors of the D: drive if any are found.
If all else fails, try 3rd party tool SpinRite.
Apr 18, 2011 | Samsung G2 Portable External HX-MU064DC/...
I have done a monthly backup on my laptop for more than a year, but this time I'm getting an error message "corrupted file system 0x81000008
Run a check disk on the Drive and select Fix bad sectors.
    Running CHKDSK through the Windows Command Prompt:
  1. Go to the Windows Command Prompt. You can do this by clicking first the Start button and then clicking the Run button. After this, type "cmd" in the Open text box and press Enter.
  2. View the displayed Command Prompt screen.
    If you want CHKDSK to run in read-only mode, type:
    CHKDSK c:
    If you want CHKDSK to fix errors and not to check bad sectors, type:
    CHKDSK c:/f
    and press Enter in the Command Prompt.
    If you want CHKDSK to run thoroughly; that is, fix errors, find bad sectors in your hard drive and recuperate still readable data, type:
    CHKDSK c:/r or
    CHKDSK c:/p and press Enter in the Command Prompt.
  3. Running CHKDSK through My Computer (Windows XP)
  4. 1
    Initialize the properties of the hard drive you want CHKDSK to run. Open My Computer. Right click your mouse on the drive in which you want CHKDSK to run. Click the Properties button and click the Tools tab. In the Error-checking box, click the Check Now button.
  5. 2
    Set up the Check Disk options by checking one or both check boxes displayed. These are labeled "automatically fix file system errors" and "scan for and attempt recovery of bad sectors". If you want CHKDSK to run in read-only mode, do not check either box. After this, click the Start button.
Jan 01, 2011 | Western Digital My Book Essential Edition...
1,152 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
