Tip & How-To about Lemond Revmaster Lemond G-Force Digital Upright Exercise Bike
Bottom Bracket & Spindle Replacement of LeMond RevMaster
Part 1 Video Discussing the Dis-assembly & Inspection of the Bottom Bracket & Spindle for a LeMond RevMaster Bike
  • This Part 1 video will demonstrate how to inspect and adjust or remove and replace the bottom bracket and spindle on your Lemond Revmaster
  • Tools needed for this procedure:
    • 8mm Allen Wrench or Socket
    • Cotterless Crank Puller Tool
    • Lock Ring Removal Tool
    • Bottom Bracket Tool
    • Phillips Screwdriver
    • 4mm Allen Wrench
    • Bungee (optional)
    • Rubber Mallet
    • 7/8" Wrench
  • To begin remove the belt cover, there are four screws
    • You will need a 4MM Allen wrench
  • Now remove the two screws on the back from the opposite side of the bike
    • You will need a Phillips screwdriver
  • Now position the crank arm as seen in the video and remove the belt cover from the bike
  • Before removing the drive belt, tighten the brake assembly so that the flywheel is locked in place and loosen the torque on both bolts using an 8mm Allen wrench or socket
    • Do not remove them at this time only loosen them by a half a turn or so
  • Using a 7/8" wrench loosen the belt idler
  • Now use a 4mm Allen wrench to loosen the tension adjustment bolt completely, but do not remove it from the frame
  • Now remove the drive belt
    • To aid in this process you can use a bungee to slide in behind the belt at the top, as shown in the video
  • Then pull away from the bike while spinning the crank arms
  • Now remove both crank bolts with a 8MM Allen wrench or socket
    • Removal of the crank bolt on the left side of the bike is the same as removal from the right side
  • Now remove the crank arms with a crank arm puller, threading the outer portion into the crank arm as shown in the video
    • Be sure to thread the outer portion in as far as possible to prevent damage to the crank arm threads or the tools threads
    • Use a 7/8" wrench to make sure the outer portion is threaded in completely
    • Now spin the handle clockwise to press the crank arm off of the bike
    • Be careful when the crank arm comes off as if you are not holding it, it can fall in the floor
    • Also use the wrench to loosen the tool before removing the crank arm from the unit
    • Now you can unthread the tool from the cranks arm by hand after removing the crank arm from the bike
  • Next inspect the bottom bracket cups for looseness, to do this use the bottom bracket tool by hand to see if you can turn either of the bearing cups
    • To further verify the adjustment of your bottom bracket use a rubber mallet to tap lightly on each side of the spindle to check for movement from side to side, if you have movement, or one or both of the bearing cups is loose, you need to re-adjust the bottom bracket. If you are only inspecting the bottom bracket and did not find any need for adjustment you would re-assemble the bike at this point
  • Once the crank arms are removed look closely at the spindle
    • It should have defined edges and be smooth
  • As you can see by the video our spindle needs to be replaced
  • Next you will need to remove the lock ring
    • The lock ring is around the bottom bracket cup on the left side of the bike
      • In the video is an example of a lock ring
    • To use the lock ring tool you slip it over the lock ring using the three notches and torque the lock ring in the proper direction
      • This one needs to be turned counter-clockwise to loosen
    • Then remove the lock ring by spinning it off the bearing cup
  • Next you will need to use the bottom bracket tool to remove the bottom bracket cups
    • Begin with the left side
      • Slip the tool into the splines of the cup and loosen
        • For stubborn bottom brackets use a 5/16"-24 x 2" bolt and some washers with a 1-1/4" wrench
          • Slip the tool into the splines and thread the bolt with the washers into the spindle
          • Get it snug but not completely tight
      • Now use the wrench to turn the cup counter-clockwise for the left side and remove it completely
    • Remove the cup from the right side now
      • Slip the bottom bracket tool into the splines of the cup and turn it clockwise to loosen
    • If you cannot get the cups loose with this method try turning the bike on its side to get better leverage as shown in the video
  • This concludes the dis-assembly and inspection procedure of the LeMond RevMaster bottom bracket & spindle
  • Click here to see Part 2, re-assembly and installation to complete the replacement procedure
Video of Bottom Bracket and Spindle Replacement Part 1 Dis assembly LeMond...
Lemond Revmaster Lemond G-Force Digital Upright Exercise Bike Logo
how to assemble a weslo pursuit ct 4.2 bike video
Weslo Pursuit CT 4.2 Recumbent Cycle: Relaxing Exercise ...
www.kmart.com > ... > Recumbent Cycles
KmartSep 30, 2012 - Arts & Crafts · Video Games · Learning & Development · Stuffed Animals & Plush · Musical ... Weslo Pursuit CT 4.2 Recumbent Cycle 1 ... With a Weslo recumbent bike you can approach exercise with ease. .... Like all in box items it takes awhile to assemble, but works great, and great value for the money.
Weslo Exercise Bike - YouTube
? 2:55
https://www.youtube.com/watch?v=2ZLzpsk4BdE
Dec 22, 2014 - Uploaded by ReviewTube
Weslo Pursuit CT 2.0 R Exercise Bike http://amzn.to/1vgiQjF ...bike assembly,weslo exercise bike amazon ...
Weslo Pursuit CT 42 Recumbent Exercise Bike ... - YouTube
? 1:41
https://www.youtube.com/watch?v=tYdlVsnDNQo
Aug 20, 2015 - Uploaded by Geraldine T. Lane
SEE MORE Best Sellers in Exercise Bikes http://amzn.to/1frY7Yr The 3 Week Diet is an ... Weslo Pursuit CT 42 ...
Weslo Exercise Bike Product Support ' ManualsOnline.
Jan 17, 2016 | Weslo PURSUIT CT 4.2 Recumbent Cycle
life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
bike serial number look up
Never mind the serial number. Bust out the tape measure and measure from the center of the crank spindle (the axle the cranks turn around) to the top of the seat tube. It's usually in centimeters, and sizes for road bikes run from anywhere from the low 40's to the mid 60's.
Jan 03, 2014 | Cycling
300 people viewed this tip
Top Lemond Revmaster Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Lemond Revmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
