Tip & How-To about Cameras
How to Transfer Pictures From Your Camera to Your Computer
There are a multiple ways to transfer photos from your camera to a computer. The best is to remove the memory card from your camera and insert it either in the SD card slot on your computer if it has one or into a USB SD card reader attached to your computer. Your computer (Mac or PC) will recognize the SC card as if it were any add on USB device such as an external hard drive. Go into "Finder" if you have an Apple or "Explorer" if you have a PC and you will find the device. Open the device/folder. In most cases there will be one or two sub-folders. Open the folders and look for files with the extension ".jpg". Those are your pictures. You can now create a folder on your desktop or another location and copy and paste or cut and paste your photos into that file. This method is preferred by professional photographers.
The second method is to download the pictures directly from your camera using a USB cable. Although I am not familiar with your particular camera, there should be a small connector in which you can plug in the USB cable that should have come with your camera. Plug the other end into a USB port on your computer. The computer will recognize your camera as a device; just as it did in the first method. Again you can copy and paste your photos from your camera to your computer in the same way as I previously explained.
The third method is to use a transfer program. Most, but not all, cameras come with one or there are many for sale. Adobe has that function in there Bridge and Lightroom software although you may consider it pricy. With the software installed you can either connect your camera to the computer with a USB cable or use an SD slot or card reader. The software will automatically download and display your pictures.
Cameras Logo
can not transfer image from camera to computer
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 17, 2013 | Olympus Cameras
transfer video to disk
ALTERNATE WAY TO TRANSFER VIDEOS AND PHOTOS TO COMPUTER
If your videos and photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 25, 2012 | Canon PowerShot SD880 IS Digital Camera
s6100
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO COMPUTER
If your photos and videos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 05, 2012 | Nikon Coolpix S6100 Digital Camera
Transferring Video
Jul 01, 2012 | Nikon Coolpix 2100 Digital Camera
how to transfer pics to computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jun 12, 2012 | Sony Cybershot DSCW310 Digital Camera
743 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
