Tip & How-To about Microsoft Windows Computers & Internet
How to Convert .DMG to .ISO
Dmg file is the disc image file which is widely used by Mac systems. Most of Mac operating systems and applications are distributed in dmg files. On Windows PC, it is very convenient to manipulate dmg files with PowerISO. You can open dmg file, convert it to iso file, or burn it to a CD / DVD disc. To convert it to iso file, please follow the steps,
  • Run PowerISO.
  • Choose "Tools > Convert" Menu.
  • PowerISO shows Image Converter dialog.
  • Choose the source DMG file you want to convert.
  • Set the output file format to iso file.
  • Choose the output file name.
Convert DMG to ISO
Computers & Internet Logo
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
Hi friends, How to convert dmg fil to iso file? I have mac os on dmg format how to create a installation dvd?
1.Double-click the DMG file to mount it.
2.Open Disk Utility, located in the Utilities folder within Applications.
3.Highlight the mounted disk, indented directly beneath the DMG file, in Disk Utility's sidebar.
4.Select "New Image" from the navigation toolbar.
5.Enter a name for the new image, select a place to save it and select "DVD/CD Master" from the Format drop-down menu. Select "OK" to start the process.
6.Open the folder containing the newly converted image file. It will have .cdr for its extension. Double-click the text to bring up the editing field to rename the file. Delete ".cdr" and add ".iso" and press "Enter." A warning will pop up, asking if you would like to keep the extension .cdr or use .iso. Select "Use .iso" and your DMG file is now an ISO file.
Thanks for using Fixya.Have a good day.
Mar 30, 2012 | Computers & Internet
my mac has been programmed not to take iphoto by previous owner how do I change that
Download and install Iphoto ..>
Click here to download iPhoto 8.1
Double-click the .DMG file to open it up. Another new icon with a name similar to the .DMG file will appear on your desktop
Sep 24, 2011 | Apple Mac OS X 1063 Snow Leopard Family...
When I download adobe reader I can't open the .dmg file after it's downloaded...what do I do to install it?
A .dmg is a disk image file made for Mac operating systems. If you are operating with Windows, you should download the windows .exe file by going to THIS site and selecting all the pertinent information.
If you are working on a Mac, you might have had some issue when downloading that partially corrupted the file, so you should try re-downloading it and trying again. Once you've downloaded it, it should be as simple as double-clicking on the .dmg icon which will open the installer window, then (depending on how it's set up, I'm not working on a mac right now so I can't check) you'll either need to drag an icon to your applications folder, or open an installer.
Jul 15, 2011 | Adobe Computers & Internet
What is a M.cdr file and how can I burn it to dvd to watch on dvd player?and the same for a dmg file?
Detailed information for file extension CDR: File classification: Graphic Mime type: application/cdr, application/coreldraw, application/x-cdr, application/x-coreldraw, image/cdr, image/x-cdr, zz-application/zz-winassoc-cdr Identifying characters: Hex: 52494646, ASCII: RIFF
Program ID: CDraw4 , CorelDRAW.Graphic.8 , CorelDRAW.Graphic.9 , CorelDRAW.Graphic.10 , CorelDRAW.Graphic.11 Associated links: XnView Other applications associated with file type CDR:
  • Elite Plus Commander Saved GameThe Identifying characters used for this association are:Hex: 45 4C 49 54 45 20 43 6F 6D 6D 61 6E 64 65 72 20 46 69 6C 65 1A , ASCII: ELITE.Commander.File.
  • Final Cut Pro CD/DVD Image File by Apple Inc.Final Cut provides Mac users editing tools, sound design, real-time motion graphics and DVD authoring. CDR files are ISO images and, if moved to a PC, can be renamed and burned as ISO files. Associated links: Ken Stone's Final Cut Pro Website
  • GameJack Virtual CD or DVD Image by S.A.D. GmbH.Appears to be an older extension. GameJack seems to use .XMD now.
  • Raw Audio-CD Data
  • Sound File This association is classified as Audio. Associated links: Linux Player
The DMG file type is primarily associated with 'Macintosh OS X' by Apple Inc.. On the Macintosh, these files are treated like a real disk. They can be created with Disk Copy, burnt to CD or mounted as a normal volume. The DMG file also comes in different formats: HFS, HFS+, UFS, ProDOS, Linux, and Fat32 and so may also require special mounting software to account for the format. IsoBuster can interpret these files directly as can other programs such as UltraISO. The program TransMac, by Acute Systems, can both open and create DMG files on a PC.
Oct 22, 2009 | Apple iMac 24" Desktop
1,213 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
