Tip & How-To about Samsung Un32d4000nd 32in 720p Flat Panel Led-lcd Hdtv
Example: How to change your mp3 player background
1.Place TV face down on cushioned table. Remove screws from the Stand. Remove stand.
2. Remove the 13 screws of rear-cover.
3. Lift up the rear-cover.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Samsung Un32d4000nd 32in 720p Flat Panel Led-lcd Hdtv Logo
i can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How do you remove the base stand from a toshiba 46lx177?
First, carefully lay the face of the TV down on a soft surface with the stand protruding over the edge of the surface, then remove jack panel cover on the back of the TV to expose the 5 screws holding the base on. Remove those screws and slide the base away from the unit. These instructions are also found on page 5 of your owners manual.
Jan 29, 2011 | Toshiba 46LX177 46 in. LCD HDTV
how can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
3) Remove the five screws shown in the diagram below. This will
4) Once you have removed all five screws holding the pedestal
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
How do you remove the bottom mount from an lcd samsung so that it can be wall mounted?
Page 85 of the manual has it, and can be downloaded here.
Here's what it says to do:
1. Place the TV face down on a soft cloth or cushion on a table.
2. Remove four screws from the back of the TV.
3. Separate the stand from the TV.
4. Cover the bottom hole with a cap.
There is a picture in the manual that indicates that the four mentioned screws are the four on the bottom back of the television.
Feb 01, 2010 | Samsung LNT5265F 52 in. LCD HDTV
1,708 people viewed this tip
Henry  Thomas
Henry Thomas
