Tip & How-To about South Shore Noble 60 TV Stand - -
SERVICE MODE AND SCHEMATIC DIAGRAM
NOBLEX 29TC656F
White balance adjustment Mode - Be used for White balance adjustment. In Factory Mode, press" BUS OFF" to enter and exit.
Default Value OK mode - Be used for default value setting before TV leaves Factory. In Factory Mode, press "S. EFFECT" to enter default value. "Wait" will be displayed in screen, when it is finished, "OK" will be displayed. It will exit factory mode automatically.
Note: Now press "SERVICE" cannot enter factory mode, you have to take the following steps to enter:
1. Setting Volume to Zero.
2. Press "V-" in cabinet and Press "Display" in RC simultaneously
Adjustment Way1. B+ Adjustment:
Apply Philips Test pattern signal in normal status, adjusting VR821 to make B+= 130V± 0.5V.2. RF AGC adjustment:
Observe monitor the collector waveform of Q101 with the probe of Oscilloscope. Select channel 2 (>70dB) from the antenna input. Enter D-mode, select menu6 to adjust RFAGC item until the monitor peak value to 0.8Vp-p.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
South Shore Noble 60 TV Stand - - Logo
sony bravia lcd display 32"
It sounds that the white balance to the set has gone wrong. Decrease the color intensity to picture to 'Zeo', and check, the TV displays the picture in pure black/white. It should be so. If not, you have to adjust the white balance adjustment. To adjust this, you have to enter its service mode option.
If you wish to get more details about how to enter, adjust and exit the service mode, check the site linked here.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 14, 2013 | Televison & Video
I have audiosonic colour television KMC TH68. The word "Factory" appear on the top just on the middle.The worse part is that is locked. One symbol like "lock" is on the left buttom in the corner.With the remote control, I can put on or off but the TV is mute and the control remote buttons non responde the some as the manual buttons on the TV.
finally have a solution for this problem. Finally got my tv back to normal. Try this: Make certain the TV is receiving a signal.
Press in sequence on the remote [MENU] > [6] >[4] > [8] > [3].
[FACTORY] is displayed.
Press the above sequence again to enter [White Balance] menu.
Press the above sequence again to enter [Adjust] menu.
Press the above sequence again to exit service mode.
Dec 09, 2010 | Televison & Video
408 people viewed this tip
Top South Shore Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a South Shore Furniture Expert? Answer questions, earn points and help others
