Tip & How-To about Panasonic Televison & Video
SERVICE MODE AND POWERS SUPPLY CIRCUIT
PANASONIC TX-20LA80F - TX-20LA80FS
White Balance Adjustment
Instrument
• Remote Control
• LCD WB meter (Minolta CA-210 or equivalent) Condition
• Switch on the TV Set. Enter Service1. Step down to Highlight line and keep the aging time more than 20 minutes.
Procedure
• After aging time above set White Raster No.12 for Highlight and No.4 for Lowlight Press the OK button to store.
• Put Minolta Sensor to the center of the LCD Panel with 25mm gap between Minolta Sensor and LCD Panel. Adjust "x" and "y" values by changing Red and Blue values.
• Press OK button to store setting.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
Televison & Video Logo
What are the white balance modes available with the camera?
The following White balance settings are available for the A2: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3-wavelength white fluorescent lamp, 3-wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Manual white balance
Click the AF-WB button and then with the wheel in the back of the camera select either K or any of the other settings. If set to K then you must go to your Menu (click menu button on back) then go to Color temp. and select your Kelvin tempature. Hope that helps....
Sep 14, 2005 | Canon EOS-10D Digital Camera
The colour on the EVF and LCD is pretty pink and nearly red
Yes it is. I believe Panasonic knows that the built in flash casts a very blue tint so they set the flash WB to very red to compensate. Therefore before the flash is triggered as when you watch the LCD. Some threads here even suggested adjust the WB further 2 knots to the red manually (press " up" a few times on the 4-way button to have better skin tone. Try it. The setting stays even when you turn off the camera.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
1,791 people viewed this tip
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
