Tip & How-To about Home
Cable Fire Protection Coatings - Cable Coating | Intumescent Cable Coating | Fire Coating | Fireproofing
Cable Fire Protection with Exterior/Interior Cable Coating for Fire Stopping and Fireproofing. Intumescent Passive Fire Protection Specialist provides Cable Coating with Fireproofing Spray, Fire Coating, Intumescent Cable Coating, Electrical Cable Fire Protection and Commercial Coating Services in USA, Canada, Africa, Middle East, Bahrain, Saudi Arabia, Turkmenistan, Malaysia
Home Logo
Top 2" of my concrete wall has eroded. How do I fix it, so it will last, and make sure new concrete bonds to the old?
Hi.
There are different kinds of concrete coating. The choice of product varies, depending if the wall is interior or exterior and on the location of the wall (for example the product used in a bedroom's wall will be different from the coating adopted in a garage).
Epoxy coating are great products that can be used in exterior or interior. Epoxy products however may smell and trigger allergies. Epoxy is one of the strongest coating for exteriors.
If the space is a living room, then it is probably better to use acrylic cement. Acrylic coatings do not smell and do not release volatile compounds. Acrylics look similar to Portland cement and are generally less strong and adherent than epoxy paste.
The application method is usually illustrated in the coating product's container. The procedure consists in cleaning the wall (you can use a power washer), applying the product with a trovel, and then checking the results after 24 hours or when prescribed in the coating's instructions.
After applying the coating you can finish the wall with paint and sealer product.
Oct 18, 2013 | Yamaha RX-V757 Receiver
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
interior and exterior fuse keeps blowing on my 1999 sunfire
if the fuse keeps blowing then there is an electrical short somewhere and this needs to be found and repaired, fuse keeps blowing so the wires don't over heat and cause a fire, do not put in a larger fuse than is required you can cause a fire
Sep 15, 2009 | 1999 Pontiac Sunfire
the glass surround on the oven door has partly come away, have tryed super glue to stick it back down but it just wont work, probably due to the heat. any ideas on what to use to re-stick it or replace??
Here's a suggestion from Rex_Mundi; 10-11-2006 at 7:24 PM..
"Best bet is to get in touch with the manufacturer. This will be some specialist Intumescent (fireproof) type glue or tape. Intumescent tape is available (I've used many different kinds over the years for glazing in firedoors/windows), but I wouldn't risk recommending anything without any word from the manufacturer. You have an added issue here (food in the oven) you don't want to risk anything that may give off fumes when very hot." I, Charlie, would agree with the above. Crazy Glue, for example, will produce very nasty fumes when heated. Another person's experience ( icecoolbabe ) : "This happened to my oven ... and I could not find a heatproof glue anywhere. I ended up going back to the manufacturer.
They sent an engineer to replace the whole oven door! He said you cannot normally reseal them properly so it's easier to replace the door." Charlie
Aug 19, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
384 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
