Tip & How-To about Beko 17WLB450S 17 in. LCD TV
Service Menu StructureThe service menu has three items: display, calibre and version 2.1 Display Display item has seven options:
a- Panel
Panel option gives information about the current panel resolution. It is a read only option and can not be set.
b- Power on time
Power on time gives information about the last update time of the SW running. It is a read only option and can not be set.
c- Backlight on time
Backlight on time option reserved.
d- Scart prescale
Scart prescale option sets the prescale values for the input sounds entering the scart input of the MSP(Micronas Sound Processor). Changing this value you can adjust the level of the output sound going to loudspeakers for all the sources except the Tuners. The range is between 0 and 100.
e- nicam prescale
Nicam prescale option sets the prescale values for the Nicam standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for Nicam sounds entering the analog sound input of MSP. The range is between 0 and 100.
f- fm/am prescale
fm/am prescale option sets the prescale values for the FM/AM standard sounds for tuner inputs. Changing this value you can adjust the level of the output sound going to loudspeakers for FM/AM sounds entering the analog sound input of MSP.
g- Agc(Automatic Gain Control) adjust
Agc adjust option sets the input voltage going to IF decoder AGC pin. Changing this value you can adjust this voltage for optimum Tuner performance. The range is between 0 and 31.
h- R/G/B Brightness/Contrast:
These are used for color bias adjustment. The range is Between 0 and 255
Calibrate
Calibrate item has nine options:
a- video format
Video format option force the video format to the desired format. Selectable formats are Auto, Pal, NTSC and SECAM.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
