Tip & How-To about Hyundai Q321 32 in. LCD Television
HYUNDAI HLCD-32ZT4 DISASSEMBLING AND POWER SUPPLY CIRCUIT
DISASSEMBLING
Lay the LCD-TV on a flat, soft and clean surface
Remove the stand.
Remove the screws remarked on red to remove the stand.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Ajin Gopakumar Google
Hyundai Q321 32 in. LCD Television Logo
how to remove stand from dell monitor + fp1800
First, find a sturdy flat surface. You will be laying the monitor on it's face - face down so get a towel, blanket or something soft to cushion the monitor on the flat surface.
Lay the monitor face down on the whatever cushion you chose.
There are two black machine screws on the back on the plate that is part of the stand. Remove these screws and the stand will slide free.
May 04, 2012 | Dell UltraSharp 1800FP 18.1" LCD Flat...
how do i remove the stand that allows the tv to stand up?
Generally there are 4 screws in the back near the center-bottom of the TV. Lay your TV down on a flat surface and remove those screws then slide the bottom out.
Mar 30, 2011 | Sharp LC46SB54U 46 in. LCD TV
How do you remove the base stand from a toshiba 46lx177?
First, carefully lay the face of the TV down on a soft surface with the stand protruding over the edge of the surface, then remove jack panel cover on the back of the TV to expose the 5 screws holding the base on. Remove those screws and slide the base away from the unit. These instructions are also found on page 5 of your owners manual.
Jan 29, 2011 | Toshiba 46LX177 46 in. LCD HDTV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
once you have insertesd the panel in the back of the tele for mounting it on the stand how can you remove it again
same way you inserted. lay the tv down flat on a soft secure surface to protect the screen. make sure there is no pressure on the stand. look for 6-8 larger screws attached to the frame for each leg of the base. remove these screws and slide out the stand. voila! hope this helps, J
Apr 09, 2009 | LG 42LG30 42 in. LCD HDTV
962 people viewed this tip
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
