Tip & How-To about iLO Televison & Video
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
Televison & Video Logo
AC adapter power connection LED blinks but not charging
This suggests to me that you need to check out the AC adapter, and see if there is an intermittent short. In otherwords a break in the wires.
AC adapter unplugged from laptop, and power, remove the AC power cord from the body of the AC adapter.
Use a multimeter set to OHM's, (1K), and connect the Positive (Red) probe lead to one of the flat bladed prongs, in the power plug that plugs into the surge protector.
Touch the Negative (Black) probe lead to one of the holes in the plug, that goes into the AC adapter 'body'.
Keep going from hole to hole, until you get a reading.
Now have an assistant gently wiggle the power cable, and see if you get an intermittent reading.
Do the same for the other plug's flat bladed prong.
Intermittent reading means replace the power cable, or if more feasible, the entire AC adapter.
Power cable proves to be fine, move on.
Plug the power cable back into the AC adapter. Plug the AC adapter into power.
Using a multimeter set to DC Voltage, touch the Positive (Red) probe lead of the multimeter, to the center hole of the plug that goes into the laptop.
(If just a symbol, the DC Voltage symbol is a dotted line over a solid line)
The Negative (Black) probe lead, touches the outside cylindrical metal shell, of the plug.
Have an assistant gently wiggle the cable, and see if there is an intermittent reading on the multimeter.
(Reading should be 18.5 Volts DC)
[There are Analog multimeters which have a scale, and a needle, and Digital multimeters that just have a digital readout.
If using an Analog multimeter the needle will drop towards 0.
If using a Digital multimeter the readout will drop to smaller numbers, or 0 ]
AC adapter checks out? Go on.
The port on your laptop where the AC adapter plugs in, is the DC Power Jack.
AC adapter unplugged from laptop, Battery removed.
Take a pencil, and gently use the eraser end to see if you can wiggle, the center pin of the DC Power Jack.
ANY perceptible movement means a problem with the DC Power Jack.
The GOOD news is that the DC Power Jack, is NOT soldered directly to the motherboard.
It slides down in a Channel on the outside edge of the Base Enclosure, and has a wiring harness coming from it.
The end of the wiring harness has a plug, that plugs into the motherboard.
The HP part number for this DC Power Harness is HP 600630-001
A) http://www.dectrader.com/600630-001-New-HP-DC-input-power-socket-connector-With-cable.html#.UD0_w6B0k9Q
B) http://www.ebay.com/itm/HP-Compaq-600630-001-DC-Power-Input-Jack-Cable-CQ42-G42-Notebook-Series-/180932154005?_trksid=p4340.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D1653940420718665976%26pid%3D100011%26prg%3D1005%26rk%3D1%26
This is a link to a free Service Manual from HP Support,
http://h10032.www1.hp.com/ctg/Manual/c02627955.pdf
Page 73 is for the Power Connector Cable.
No damage to the DC Power Jack, and the harness is not slightly unplugged?
Now you have real problems.
You have a bad Power MOSFET,
A) MOSFET:
http://en.wikipedia.org/wiki/MOSFET
B) Power MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET
C) http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
However it doesn't take a rocket scientist to replace. (Sorry Gort)
These SMD's use a J-lead contact. Simple unsoldering, and soldering.
(Better be fast though as you don't want to overheat a power transistor. Better be good, because you don't want any cold solder joints)
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 28, 2012 | HP Computers & Internet
how to change blower motor in. 99 grand Cherokee
Check this procedure...Blower Motor Resistor and Controller Replacement
REMOVAL
1. Disconnect and isolate the batten' negative cable.
2. Depress locking tab and unplug the wire harness connector from the blower motor
resistor or controller (power module).
3. Depress locking tab and unplug the resistor or controller connector from the blower
motor.
4. Remove the 2 screws that secure the blower motor resistor or controller to the
heater-AC housing.
5. Remove the blower motor resistor or controller from the heater AC housing.
INSTALLATION
1. Install the blower motor resistor or controller to the heater AC housing. The
housing is indexed to allow (controller power module) mounting in only one
position. Tighten the mounting screws to 2.2 Nm(20 in. Lbs.).
2. Plug in the wire harness connector to the blower motor resistor or controller.
3. Plug in the connector from the blower motor resistor or controller to the blower
motor.
4. Connect the batten' negative cable.
Hope this helps (rerember to rating this and leave a testiomonial).
Sep 30, 2011 | 1999 Jeep Grand Cherokee
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black. Please don't suggest going to control panel, as I can't get that far. PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING so plz give me solution my mobileno:8019651533
First of all check your VGA cable is working or not.
If VGA cable is ok than do the following steps.
  1. Turn off all peripheral devices connected to the computer.
  2. Disconnect the computer's power cord from the AC power source (wall outlet or power adapter).
  3. Remove the computer cover.
  4. Locate the battery on the board (see figure below).
  5. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the "+" and "-" on the battery.
  6. Wait for 1 to 5min then re-place the battery back again.
  7. Re-place the computer cover.
  8. Plug the computer and all devices back in.
Second step you can do is
1) Remove the RAM from the RAM bank clean it properly and insert it back again.
If still you are facing the same problem ... you can Remove the CPU fan and put some cooling paste on top of CPU and re-place the FAN back.
Jul 06, 2011 | LG Flatron L1710S 17" LCD Monitor
canon error p08 Problem
Follow the instructions step by step
1. Turn off printer, cable power still plug in,
2. Press Stop/Reset button don't release
3. Press Power Button don't release and than release Stop/Reset button
4. Press Stop/Reset button 2X , wait until service mode to " 0 "
5. Turn off printer, cable power still plug in
6. Press Stop/Reset button don't release
7. Press Power Button don't release and than release Stop/Reset button
8. Press Stop/Reset button 4X , wait until service mode to " 1 "
9. Turn off printer, and loose cable power, wait one minute.
10. Connect cable power, turn on printer again, now this printer ready to use.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 10, 2011 | Computers & Internet
821 people viewed this tip
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
