Tip & How-To about Sony Televison & Video
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
Televison & Video Logo
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
SEQUENCE (cont.)
(t02)
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
GE Dryer error code E61
SEQUENCE (cont.)
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
Mar 16, 2007 | GE DBVH512EFWW Dryer
1,525 people viewed this tip
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
