Tip & How-To about Insignia Televison & Video
SERVICE MODE POWER SUPPLY AND INVERTEE CIRCUIT
White balance adjustment
Pre-adjustment
The set should be working for over 30 minutes before white balance adjustment so that it can be in a stable state. Use white balance apparatus CA210 and change to BBY channel to adjust white balance; Only need to adjust chromaticity coordinates when color temperature is 10000K (namely "COOL") for the unit. To meet testing requirements of BBY when color temperature is 8000K or 6500K, make sure chromaticity coordinates of bright scale is X=280 ± 5 Y=288 ± 5, chromaticity coordinates of dark scale is X=280± 8 Y=288± 8; Manual adjustment of both groups of white balance datum YPbPr white balance adjustment.
FOR MORE CHECK
Electronics Equipment Repair Center
Televison & Video Logo
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
May 05, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
The pictures are too blue.
It sounds like a White Balancing problem. I'd guess if it's set on Auto WB, then you'll need to do it manually. Some digital cameras tend to produce that blue tint when left to white balance themselves.
If you don't understand completely let us know the exact model of the camera and I'm sure somebody can talk you through it!
Oct 01, 2008 | Cameras
My EOS 400D takes blue hued pics
You may have the white balance set incorrectly. If so, set it to "auto white balance".
Sep 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
1,289 people viewed this tip
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
