Tip & How-To about Toro 51599 Electric Blower 12 Amp
Before discarding your Toro 51599, check the reset button.
If your blower doesn't work, check the reset button which is located under under the handle. It can be depressed with a screw driver.
Toro 51599 Electric Blower 12 Amp Logo
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
dc17 won't turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor.
Nov 18, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
blower motor dosen't work on the 2 lower settings
more than likely needs a blower resistor it is located somewhere under the dash on the right side more than likely ,
Nov 21, 2011 | 1999 Chevrolet Silverado 1500
brand new machine red button doesn't depress- it feels springy but doesn't click therefore brush not working
Hi Moya,
I'm sorry to hear you're having difficulties with your DC24. If the brushbar won't rotate, it may simply need resetting. Please follow the steps shown in the video below to reset it - make sure you have the cleaner reclined into the vacuuming position before testing it, as the brushbar will never run when the cleaner is standing upright.
However, if this doesn't restart the brushbar, it's best if you get in touch with us directly so we can help. You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 13, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
1,840 people viewed this tip
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
