Tip & How-To about Computers & Internet
Common Troubleshooting Techniques & Strategies
(1) Trial-and-error
Personal computers are highly modular by design. The most powerful trouble-shooting technique is to isolate the problem to a specific component by trial-and-error. Swap compatible components and see if the system still works. Try different peripherals on different machines and see if the same problem occurs. Make one change at a time.
(2) "It's the cable, s-----."
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card and sound card are inserted correctly and didn't "pop-up" during transportation.
(3) Don't be frustrated!
Don't be afraid of computer problems. It is often the best opportunity to learn. Trouble-shooting is part of the fun of owning a computer. Imagine the satisfaction you could get by solving a problem yourself.
Of course the fun could ran out quickly once you are frustrated and have spent too much time on the same problem. If you feel frustrated, it's time to leave it for a while and go back with some new ideas or call someone who can help. Rule of thumb: You shouldn't spend more than three hours on the same problem at one time.
(4) Take notes!
Take notes of what you have done and all the error messages. You may need to use them later. For instance, when you see an unusual blue screen with an error message, copy the entire message onto a piece of paper. In many situations, that message may point to the right direction in getting the problem solved quickly.
(5) Take a look?
It's OK to open a computer case and take a look inside. There is only 5V and 12V DC voltage supplied to the components outside the power supply. Those who have never seen the inside of a computer are often amazed by how simple it looks. Of course, still always power down and unplug the power cord first.
Computers & Internet Logo
HOW TO INSTALL POWER DIRECTOR TO PERSONAL COMPUTER?
Installing the Trial Version
1. Navigate to the Cyberlink PowerDirector page and click the "Free Trial" link.
2. Click "Try Now" and type in your name, email and country. Click "Download Now" and click "Run" to begin the download. When the download is complete, the automatic installation will open.
3. Click "I Accept" after reading the terms and agreements. Select the location to install your program and finalize the installation. You do not need a CD key with the trial version.
Dec 30, 2010 | CyberLink PowerDirector 3 for PC
Dometic Rooftop Dua-therm unit 1997.Fan runs,but no power to compressor.Is there another relay or fuse besides the breaker?
you need alot more info to help you. Which fan runs. The compressor could be out on high pressure if the cond fan failed. You really need to do a lot of trouble shooting to isolate the problem.
Aug 10, 2009 | Heating & Cooling
Automatic restart
This is may occur due to following reasons:
1.please check BIOS power settings..
2.If boot file got corrupted this issue may occur.
trouble shooting steps:
Open Command prompt in Computer
Start >> Run >> type cmd >> press enter.
Now type chkdsk /f
now type : y
then restart the PC it fixes the boot file errors.
Clarifications required:
Please let me know are you getting any error while restarting computer. While Startup Windows XP does it opening any programs automatically or not?
Feb 18, 2009 | Acer TravelMate 2300 Notebook
tv trouble shooting techniques
change the TV to another outlet.
check for any blown fuses.(look in manual)
check the TV's lamp.(look in manual)
Aug 19, 2008 | Televison & Video
2 fuses blow on power up
Its the power pack on the system board. It has a short in it and causes the fuses to blow.....if your farmilar with replacing it you can order the part though the manufacturer.
Nov 15, 2007 | Pioneer SD-582HD5 58" Rear Projection...
201 people viewed this tip
David Payne
David Payne
