Tip & How-To about Star trac Exercise & Fitness
Star Trac 4000 Treadmill Deck Bushing Replacement
Replacing a Deck Bushing or Deck Stop Delrin Rod on a Star Trac 4000 TreadmillTools Needed: Phillips Screwdriver, Pliers (optional). Tools needed may vary depending on your hardware.
  1. Switch the power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Loosen and remove the old deck bushings.
  4. Stubborn deck bushings can be removed with the assistance of pliers, once the screws have been loosened completely.
  5. Install the new deck bushings. (Check with mfr. for proper torque during install process.)
  6. Now, plug in and power on the unit.
Video of Replacing the Deck Bushing on Star Trac 4000 Treadmill
Exercise & Fitness Logo
replace 2007 Oddysey tailgate light assembly
To Replace a Tailgate: Tools needed for the replacement:- Star shaped sockets- Flathead Screwdriver- Long Nose Pliers- Shop Light- Dremel w/ disc cutter for plastics, Remove the 2 outer long star shaped screws: Close Tailgate and pull down and out the handle bezel. The bezel itself its being held by 2 plastic anchors. To remove the handle from the tailgate we need to open it. Pull the linkage from both sides inward and the tailgate should open. Remove the 3 large star shaped screws-------------------------------------------------------------------------------------------
Tacho Pro 2008
Mar 18, 2013 | 2007 Honda Odyssey
2001 f350 diesel shift lever is loose
First . take off your panel that covers the fuse panel by your knees. put your head up under the dash and look for the shift linkage. some times the screws that hold the plate on where the linkage attaches break off. second things that go bad are the two plasic bushing that the shifter rod is held down by get worn out. Everything you need is a dealer only Item. If you get into and need help. Call me at 570-878-5222 Its a real easy fix if you know what your doing. The only tools you will need are....#30 torx socket, straight pick, phillips screwdriver, small prybar or a large flat screwdriver.
Dec 08, 2012 | 1996 Ford F350 Crew Cab
how to install rod bushings on a harley , 98 softail 1340cc.
Replacing rod bushings is not a difficult job but you must have some special tools if you're going to do it with the crank assembly still in the cases.
Harley makes a special tool with which you remove and reinstall the bushings with. Basically, it's a couple of metal cups and a bolt. You ues the cups in one way and pulls the old bushing out. Use them the other way and pulls the new bushing back into the rod.
Once you have the new bushings in place, you must have a special **** with which to **** the new bushing to the correct inside diameter.
If you have the crank out of the cases and the crank is disassembled, you can have the rod bushings replaced the way most other such bushing are replaced in a machine shop. They have equpment to press the old bushings out and new ones back in and then hone the bushing to size. Simply take them your rods, the new bushings, and a new piston pin for sizing the bushing too.
I do not have the part numbers for the tools needed to do this job as I don't have a service manual in front of me. If you need the numbers of those tools, contact me directly at wd4ity@bellsouth.net Good Luck!
Jan 24, 2010 | 2000 Harley Davidson FLSTC Heritage...
333 people viewed this tip
Top Star trac Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Star trac Exercise and Fitnes Expert? Answer questions, earn points and help others
