Tip & How-To about Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045 Logo
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Mar 18, 2014 | Life Fitness 95xi Elliptical Crosstrainer
where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
592 people viewed this tip
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
