Tip & How-To about Proform Exercise & Fitness
How to Verify Power from a 110V Outlet
Video about How to Verify Power from a 110V Outlet
  • The first step of troubleshooting a power issue with a machine equipped with a power cord is to verify that the outlet being used is working
    • This video demonstrates a simple method of testing the outlet
  • Make sure that the outlet and appliance have matching plug and receptacle before plugging in
    • Failure to do so could result in injury and/or damage to electrical circuit and/or appliance
  • This procedure is a quick and easy way to test the functionality of a 110 volt outlet
  • Plug in a small appliance such as the fan used in the video and make sure the appliance works
    • If so, you know that the outlet is not your problem
  • You could also use a light, small lamp, or radio for this test
    • Any small appliance that you can plug in and turn on and know the appliance is working
  • This completes our demonstration of testing a 110V outlet for power
Exercise & Fitness Logo
MFC-8710DW has no power
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
Jan 02, 2014 | Brother printerall-in-onelaser mfc8710dw
Lexmark E450dn will not power on, power cord is working
This issue may be due to one of the following:
  • An incorrectly set power switch.
  • An improperly functioning power outlet, surge protector, or power supply backup.
  • A poorly connected power or data cable.
  • A defect with a third-party (i.e. non-Lexmark) option such as a memory card.
  • An incorrectly connected or malfunctioning optional paper tray.
  • A malfunctioning printer component.
Please try the following steps:
Step Action 1 Make sure the power switch is in the "on" position. If it is, power off the printer. 2 If your printer's power cord is plugged into a surge protector or uninterruptible power supply (UPS), unplug it and connect it directly to a grounded wall outlet. Some of these devices can interfere with consistent electrical flow and cause the printer to fail to power up properly. 3 Disconnect the power cord from the back of the machine and then reconnect it. Make sure the power cord is plugged in all the way. 4 Disconnect any data cables (parallel, USB, Ethernet) from the rear of the printer. Any defect in a data cable may cause an electrical short circuit that could cause a loss of power to the printer. 5 Turn the printer on, this time with only the power cord connected and plugged directly into a grounded wall outlet. 6 If the printer still fails to power up, power off the printer once more. Verify that the outlet is working properly by connecting another device to it to see if it receives power. You can also try plugging the printer into a different grounded outlet. 7 If possible, try another printer power cord. 8
Verify that the printer is the correct voltage type for the environment in which it is being used. A 110V (low-voltage) printer will not work properly in a 220V (high-voltage) environment, and vice versa.
  • NOTE: Look at the rear of the printer and locate the electrical specifications sticker. Verify that the voltage rating on the sticker is the correct voltage for your printing environment (i.e. 110V or 220V).
9
Remove any third-party (i.e. non-Lexmark) options, such as memory cards, as they may interfere with proper printer functioning. Also remove any paper-handling options such as an optional second paper tray. 10
Attempt to power on the printer once more with all options removed, having verified that other devices work from that power outlet.
If there is still no power, the printer may require service to fix the issue. Please contact Lexmark Technical Support or a local service provider.
Oct 14, 2011 | Lexmark E450dn Laser Printer
hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
screen went blank while still on. unplugged power cord and when I plugged it back in the power on light went green. Problem remains
Resolution:
Follow the steps below to troubleshoot this issue.
Verify that the AC power cord is connected securely to a working wall outlet.
Unplug the power cord of the television from the AC outlet.
Let the television remain without power for 1 minute.
Plug the power cord back into the AC outlet.
Attempt to turn on the television.
NOTES:
If the issue is still unresolved after completing all of the troubleshooting steps, service will be required.
Make a note of the STANDBY or TIMER flash pattern when referring the television to service.
Aug 13, 2008 | Televison & Video
729 people viewed this tip
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
