Tip & How-To about Clothing Accessories
How to fix smelly or odourous, shoes, trainers or boots
Modern trainers and many types of shoe or boots may smell awful. Get some anti-fungal shampoo, make a dilute solution (not too dilute) and pour some into the boots or put the trainers into bowl of the solution and allow it to soak in and then dry out. The fungi and bacteria will be killed and this should last a few months. A second treatment may be necessary. The shampoo must contain one of the new (--onazoles) such as ketoconazole. You are looking for the ingredient name to end in onazole or very similar. Old antifungals are useless. transformed my work boots and stopped my socks from smelling for a few days when previously they would smell and need changing every day. Did wonder about soaking the work socks as well.
Clothing Accessories Logo
My washer smells of mildew
This is an indication of a fungal build up inside your machine.
Pour about two cups of vinegar into the empty machine, add the soap and run it empty on a shortish wash cycle.
This should clear the smell, if not repeat again after a while.
Sep 09, 2014 | LG Washing Machines
What are the benefits of using lavender oils for massage?
Lavender is one of the most versatile herbs. Its various health benefits range from pain relief and mental clarity to use as an anti-bacterial cleanser and a natural deodorant.
1. Anti-Bacterial
2. Improve Complexion
3. Anti-Fungal Remedy
4. Insect Repellent
5. Calm Nerves
6. Clear the Mind
7. Alleviate Pain
Mar 04, 2013 | Health & Beauty
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
713 people viewed this tip
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
