Tip & How-To about Sharp Office Equipment & Supplies
Copier Lingo, Jargon, Keywords Explained
When you're shopping for copiers you'll often see a bunch of acronyms or words that don't make any sense to you, the layman. That's what we industry insiders are for, to help translate these words and phrases into coherent thoughts. If you come across any copier lingo that isn't on this list, just contact me and I'll let you know what it means, then I'll add it to this page for future reference.
In alphabetical order:
  • ADF = Automatic document feeder. Every machine since the turn of the century has had one of these. There are variations of this term. See RADF and DHADF.
  • Bypass Tray = an additional paper source that normally supplies envelopes, labels, or heavier paper. It can be used to supply any paper that you don't have readily available in your regular paper trays
  • CPM = copies per minute
  • Developer = A finely ground metal material that adheres to the drum magnetically to transfer an image onto toner, which makes an image on your paper.
  • DHADF = Dual head automatic document feeder. Sometimes call scan squared, this feeder has two scanners that scan both sides of an original in one pass without flipping it around
  • Driver = A print driver is installed on your computer to communicate properly with your model of printer.
  • Drum = The drum is an essential part of the copy process because it "receives" the image from the developer and transfers it onto the paper with toner
  • Drum blade = The blade wipes the drum clean on each rotation. If you have an old drum blade you'll start to find lines on your prints.
  • Duplex = 2-sided printing, copying, or scanning
  • Finisher = An additional piece of hardware that enables the copier to staple and offset sort your printed documents
  • Fuser = The hot section of the copier that fuses the toner off of the drum onto the paper.
  • LCC = Large capacity cassette. This cassette will hold 3,000 or more sheets. It is an additional cost, hardware and adds to the footprint of the copier
  • Ledger Paper = 11 x 17 is commonly referred to as ledger, although it's more often just called "11 x 17"
  • Legal Paper = 8 ½ x 14 paper is commonly referred to as legal
  • Letter Paper = 8 ½ x 11 paper is commonly referred to as letter
  • MFC = Multifunction copier. Implies that it prints and scans along with copying.
  • MFP = Multifunction printer. Most "copiers" nowadays are MFPs.
  • PPM = pages per minute, a modern day variation of CPM since it implies more than just copies
  • RADF = Reversing automatic document feeder. This feeder will automatically flip an original to make a two-sided copy.
  • Saddle Stitch = Another form of finisher that will fold and staple documents like a booklet
  • Sorter = Another term for finisher. It will offset sort your documents and some manufacturers have a stapling function.
  • Toner = Toner is the "ink" of laser printers. It's a VERY fine powder that moves like a liquid, use caution when replacing your toner cartridge. Most toner cartridges nowadays have no open holes for toner to leak, but you should still be careful when handling one.
This should be a big help if this is your first time shopping for the correct copier for your office. If you have found this page you're probably in the process of shopping for a copier, so why not Request a Quote from me while you're at it?! I reside in Houston where I provide free delivery and installation of anything I sell, and I work with network of Sharp dealers all over the USA to get you what you need and have it installed by a professional. Don't delay!
what is the meaning of the word,Divine
Divine, adjective, as in divine intervention: Apparently Robert Madden has only survived this long through divine intervention as he obviously doesn't have the common sense to use an online dictionary or (gasp!) a real book!
how to save a file in word
You have several choices when saving Microsoft Word files for use on another computer.
1. Ensure that both computers have the same version of Microsoft Word or that the versions being used are compatible with each other.
2. Save the Word document in the format which can be opened on the other computer, i.e. don't save as Word 2007 or 2010 .DOCX if your other computer only has Word XP or 2000 or 2003 - save instead as Word 95 - 2000 .DOC format.
3. If you don't have Microsoft Word on the other computer, install a copy of the free Kingsoft Office 2012 Suite which is able to open and edit all current Word document formats.
2answers
i don't know how to get back my Microsoft word on my computer.
Hello, there are many posibilities your MS Word is still in your computer, If you have Windows XP click on Start menu then click on all programs, and look for Microsoft office folder, once you have your mouse over that menu, it will show all your MS Office applications, to get back your MS Word icon to the desktop, right click on Microsoft Word's icon and then click on Send to, then click on Desktop (Create A Shortcut).
Almost the same procedure is used with windows Vista/Seven: Click on start menu and type in the search box the word: 'Word', you'll see all the matches, there must be MS Word among the matches, right click on it and send the icon to desktop as a shortcut.
If you don't find The office folder nor the word Icon, is time to 'restore' your system, on Windows XP press F1 key and under the Choose a task subtitle, look for something like 'Undo previously done changes using System Restore', system restore window will appear, click on next and choose a date before the problem started happening, for example if the problem started on wednesday and your most recent restore point was on monday click on monday and start the restore process by clickng 'next' button.
The same procedure is very similar on Windows Vista and Seven, for these OSes you'll have to search for 'System Restore' in the F1 help menu and follow the instructions given.
If you're still having problems finding MS Word my recommendation is to go to a computer store and seek for professional help on the subject.
I hope these tips help, best wishes.
Have a nice day.
can you refill lexmark s305 cartridges
Yes, although i would'nt recommend you to do it yourself. there are specialized shops that refill cartridges. I don't think that buying an original refill is a must, so if you want to look for a shop near you that refill's cartridges and ask for the price, i think you'll find it more interesting than buying a new one.
I don't have a disc to install it is there any way I can install it with out a disc.
In the future, please be more specific so that we can provide you with more specific help. To answer you question in a general sense, yes, you can go to the manufacturer's website and go to their "Support" section and look up your printer by model number and download the driver software from there. Just do a Google search for you brand and model number and the word "drivers." You'll find it.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
