Tip & How-To about Apple Computers & Internet
How to convert iTunes videos to unprotected M4V format playable on iPod
M4V Converter Plus is a powerful M4V DRM Removal tool. It converts M4V videos to MOV format in high speed with great quality. It is designed to convert DRM M4V video you purchased to QuickTime MOV, iPod, iPhone format. Moreover it can also convert almost all video formats could be played on your iTunes to other common video formats like MOV, MP4 or unprotected M4V.
Follow the steps, you can convert your DRM M4V movies to iPod supporting M4V fomat easily.
Step 1: Load M4V movies you want to convert.
Click "Add Movies" button, search your DRM M4V files according name, then select the files, click "Add" button.
Step 2: Select output format and output folder.
In the output droplist, select "For iPod (*.m4v)" in profile droplist.
Tip: If you choose "For iPod (*.m4v)", the output video is for iPod, and the video maximum size is 640*480.
Step 3: Start Converting.
You can press "Convert" button or click the menu Control->Start Converting to start the converting, and now the converting process begins.
Step 4: Check Output video files' Quality
After the converting process finished, you can select one of these video files, and then play it to view video effects whether it is satisfied. If you are not satisfied, you can re-customize the output setting to convert the video to other format to meet your need.
Step 5: Find the converted files quickly
After you open the converting box, you can see the default output path is/Users/username/Documents/M4VConverter Plus, but you can click the button Browse to customize the output location as you like. And Click the Open button to view the output folder quickly.
If you check the "Open folder when conversion completed", after all the files converted, it will open the output path.
You can find more info at
M4V to iPod convert M4V to iPod with M4V Converter Plus
Computers & Internet Logo
How to burn iTunes purchased movies to DVD disc?
Hi, Carol. Generally speaking, the iTunes purchased movies can't be copied anywhere .due to the fairplay DRM protection. It of course can't be burnt to DVD disc.
But there are some 3rd party iTunes DRM removal software to help you. I recommend you take TunesKit iTunes DRM Media Converter for Mac and BurnX freeware for a try. iTunes DRM Removal for Mac Remove DRM from iTunes Rentals and Purchases...
TunesKit for Mac is a professional DRM removal application to help Mac users remove DRM from iTunes purchased and rented movies and convert iTunes DRMed M4V to MP4 format with lossless quality. After converted, you can burn the DRM free MP4 video to DVD disc freely with any DVD burner tools, like Burn, BurnX, Simply burns, Liquid CD and so on.
If you are running Windows, you can try Aimersoft DRM Media Converter and use the same Windows DVD Burner tool.
How to Burn iTunes Purchased M4V Videos to DVD
Aug 21, 2014 | Apple iTunes
Can I remove DRM from iTunes videos
Hi, here is a video tutorial which can resolve this problem. And the recommended software used in the video tutorial is iTunes DRM Media Converter for Mac
Hope it's helpful!
Apr 11, 2014 | Apple iTunes
How do you change a file extension from .m4v (which the WD tv mini media player will not accept) to.avi (or any other suitable/acceptable extension)?
it is best to use AVI video converter
not only will it convert your m4v to AVI format, but you can switch it to any other format any time you want
http://www.avs4you.com/AVS-Video-Converter.aspx
May 29, 2011 | Televison & Video
862 people viewed this tip
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
