Tip & How-To about Bits Limited Smart Power Strip Scg5 W/ Coax, Fax/modem Surge Protection 7 Outlet
Surges -- How to keep them from damaging your electronic devices.
Surges give me more than half of my repair jobs,so [1] it is best to simply unplug ALL of your best devices when you expect to be away for awhile, and [2] your purchase of a surge limiter will cost you less than $30 on the net, or less than $40 at Walmart or Lowes, or Home Depot, and be sure to buy a 6' length of coaxial cable at the same time unless you have one hanging around. [They are right now probably in a closet among a whole bunch of stuff that's just barely too valuable to throw away -- stuff that your sweetie has threatened to chuck any minute now.]
Your surge limiter must be rated at 3000 joules or more, and must have at least two shiny threaded 3/8th inch projections on it to accommodate coaxial cables. The limiters are easy to hook up, but you can email to me for freebie coaching if you need to. I am at GrampsCanHelp@gmail.com
Lightning will jump limiters sometimes, and they get tired after 3 or 4 years so must be replaced, but thereafter they remain valuable as power strips. They are far far from being perfectly protective because fragments of lightning strikes jump them and damage them, but they are the best devices that low cost technology has been able to bring to us to date.
[A 'back-up' power supply containing a battery and isolation transformer will be more protective but costs 3 to 6 times as much. You may wish to get more details about them from me, but they should only be considered for VERY expensive or very precious devices.]
Hope this helps.
Gramps
Bits Limited Smart Power Strip Scg5 W/ Coax, Fax/modem Surge Protection 7 Outlet Logo
Power surge made my Frigidaire stove show a F9 code
F9 is a door lock error. Sometimes when the power surges the door locks then unlocks. It is possible your door lock could actually be broken, however many times when the EOC fails, it will show an F9 when it should show F1. I would guess that your EOC (main computer board) is fried. Try unplugging it for 24 hours then press the door lock button once you plug it back in. If there is no error code when you plug it in but the error code comes back when you lock the door, you probably have a problem with the lock.
Jun 25, 2014 | Frigidaire PLEF398AC Electric Kitchen...
won't idle and surges
May be coil when hot.
Jun 03, 2013 | Motorcycles
what would it cost to adjust or repair valves, the motor is making a clicking sound?
There is no valve adjusting to be done, I expect what you are hearing are lifters that have begun to fail, very common on the 3.0 liter. These can be replaced with common garage tools however you'll need to remove the rocker arms, on a 1-10 basis I'd give this job a 6.5 on a dificulty rating.
Please let me know if I may assist further.
Best regards,
Tom
Aug 28, 2010 | 2000 Mitsubishi Montero Sport
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
phillips 52" tv
It might be simply a matter of having someone adjust the magnetic rings on the yoke of your picture tube to refocus it - a lost art.
A 15 minute job for a seasoned veteran, perhaps, but expect to pay a minimum charge of 1 hour's labour, at $85-90 CDN.
Sep 18, 2008 | Philips Magnavox 27MS343S 27" TV
254 people viewed this tip
Top Bits Limited Computers & Internet Experts
David Payne
David Payne
Are you a Bits Limited Computer and Internet Expert? Answer questions, earn points and help others
