Tip & How-To about Eclipse Audio Players & Recorders
Connecting an Eclipse MP3 Player to a Computer
Many people have found that their computers do not recognize the Eclipse mp3 Player, even after connecting with a USB cable. I had the same problem but discovered that the problem lies with the cables themselves. I have several USB 2.0 5-position cables that fit the Eclipse USB port perfectly, but only ONE of them actually works - the cable that came with the player itself. If you've lost this cable, you may be in trouble.
Attached is a screen-grab of the type of USB plug and port involved. You don't see them around very much anymore, and I have no further advice if your player doesn't have a USB port of this shape.
When I connect MP3 player to laptop via USB cable, it does not show up in removeable devices. Laptop does not recognize it. Worked previously. Please help.
is it powerd on? some devices need to be on before the computer can recognize it like my digital camera has to be on before i can use it via the USB cable
Jan 16, 2016 | Eclipse Fit Clip Plus 8GB* MP3 Player
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
how do you download freemusic to my eclipse cld 4gb mp3 player
First you download the music from MP3 music sites to your computer, then connect the USB cable to your player and plug the USB cable into the USB port of your computer. The computer will see the MP3 player as an external storage device then copy the MP3 music files from your computer to the MP3 player.
Mar 09, 2012 | Audio Players & Recorders
I can't even figure out how to charge my Eclipse 4 gb portable media player. Can't figure out how to find an online manual. And I CAN'T EVEN FIND THEIR WEBSITE. thanks for your help. -James
Your MP3 player is charged by connecting the supplied USB cable to the player and then connecting it to a computer's USB port. The computer will see this as an external storage device.
Mar 18, 2011 | Mach Speed Audio Players & Recorders
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
1,452 people viewed this tip
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
