Tip & How-To about Whirlpool Washing Machines
Random 10 common Major Appliance Problems With Parts Pictures
TO error on a samsung dryer. THERMISTOR OPEN
http://fixitnow.com/wp/2011/07/09/tech-sheet-location-and-thermistor-information-for-samsung-dryers/
All samsung defrost Thermistors
http://www.repairclinic.com/Shop-For-Parts/a4b160c61/Samsung-Refrigerator-Sensor-Thermistor-Parts
Washing machine DRIVE COUPLER/GEAR CASE AND ALL OTHER TOP LOAD WASHERS 2008 *normally* or older. KENMORE and WHIRLPOOL
(specialty tools may be required to dissasemble your machine -- See
( http://www.justanswer.com/appliance/71ndo-maytag-lat9356aae-top-load-washing-machine-trick.html)
http://www.searspartsdirect.com/washer-repair/symptom/WASH009.html
Thermal Fuses and thermal limiters (Whirlpool thermal fuse for new and most dryers included)
http://www.ratecore.com/kitchen/kitchenaid-dishwasher-no-power-thermal-fuse/
https://www.google.com/search?q=Tcos+Appliances&safe=off&rlz=1C1CHFX_enUS594US594&biw=1600&bih=775&source=lnms&tbm=isch&sa=X&ei=ZjfOVPOxBpPfgwTDnYOADg&ved=0CAcQ_AUoAg#safe=off&tbm=isch&q=Thermal+limmiter+Appliances
Washing Machines Logo
whirlpool duet dryer GGW9250PW3?
On thing I have learned as a WP tech for some models the service manual does not explain the error code has to be reset to get unit to operate for dryers normally the tech sheet is up in the control panel
Aug 28, 2014 | Whirlpool Dryers
when the machine on it showing f-01
Tilt the washer back and support it with wood blocks so you can remove the kick panel screws and get the tech sheet from inside.
F/01 is an EEPROM error on the CCU. A power glitch may cause this error; unplug washer or disconnect power for two minutes. If broken, then you'll need a new CCU-- not a rare event on this washer.
s there a link to the diagnostic test for the washer? I found the one for the dryer here:
http://fixitnow.com/wp/2007/06/19/whirlpool-duet-sport-dryer-diagnostics-and-fault-codes/
Jun 06, 2010 | Ariston Technologies AWD121WH
EI or E1 appearing
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel. Get to it by removing the bottom quarter panel.
http://fixitnow.com/2005/03/appliance-repair-revelation-peek.htm
http://www.repairclinic.com/referral.asp?R=154&N=548392
part link above.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208558723.pdf
tech link above, circuit diagram.
May 23, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
the dryer keep saying E1
Hi, Error E1 indicates a thermistor failure. The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F. When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
Normal thermistor resistance values: 60 degrees F. - 15.3K ohms. 70 degrees F. - 11.9K ohms. 80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Code E1
E1 or E2 Thermistor Failure
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
1,937 people viewed this tip
Dan Webster
Dan Webster
Sal DeAngelo
