Tip & How-To about LG Washing Machines
LG F1256QD washer bearings, spider and LE error code!
I have an LG F1256QD front loading washer and it started rumbling on the spin cycle. When I finally got round to doing something about it, it would give a metallic screech on the wash cycle too! I decided to replace the bearings and the spider as it would be a right pain to strip it all down and then find the shaft of the spider was damaged - this is where the water tight seal is made! I ordered the parts from Buyspares and they have a very good video explaining how to do the job. It means the drum has to come out of the washer so be prepared! Simply take your time and follow the instructions. I allowed 12 hours to do the job and I wasn't far wrong!
The hardest part is getting the bearing OUT of the drum. On the video, they say to use a soft face hammer and a screwdriver to tap the bearings out. Forget that - I had to use a 10lb club hammer and it was a long struggle. Lots of WD40 or similar rust penetrator and lots of patience!
When it comes to the spider, you will find that LG have used screws with a soft steel head. Using 1/2" drive and 10mm socket simply rounds the edges of the screw head. Better to use a 1/4" drive and use a heat gun to warm up the casting where the screws are fitted. A common complaint is about the screws. This is due to LG using a thread locking adhesive on the screws so heating them up softens the adhesive and makes it slightly easier to get those screws out! I fitted a new spider as there was signs of wear on the old one and the water tight seal is made between the base of the spider shaft and the bearing cover.
Reverse the process until everything is back together. Don't be surprised if you get an LE error code on start up. I discovered many folk are advised to replace the hall effect sensor on the motor however..........The motor should look like some copper coils sitting on a round white frame. If the frame is covered in brown dust - and you've had the screeching - this is due to the magnets in the rotor cover that goes over the motor. You end up with magnetic dust everywhere. A good tip is to clean out all the material between the magnets - an old toothbrush is helpful - and take some Isopropyl Alcohol (rubbing alcohol) and throughly clean the motor coils, frame and hall effect sensor, paying particular attention to the connector pins. The sensor tells the rotor where it is and a sure sign its confused is to put the machine on a rinse cycle with nothing in it and watch the inside of the drum. If the drum makes twitchy movement right and/or left then the sensor is confused and needs a good clean out.
Rather than spending yet more money, this worked first time - just remember to try and get both parts of the motor as clean as possible!
Hope this is of help!
Washing Machines Logo
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
low rumbling noise and washer won't spin
Remove access panel and check to see if the belt is on.
Nov 12, 2012 | LG WM-2277HW Front Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
2,078 people viewed this tip
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
