Tip & How-To about Cameras
The Best Way to Transfer Pictures From Your Camera to Your Computer
The best way to transfer pictures from a camera with an SD memory card to a computer is to do it outside of the camera. If your computer does not have an SD card reader built in, you can buy an external USB card reader for $20 or less on E-bay, Amazon, etc. Remove the memory card from the camera and insert it in the card reader. Your computer will treat the card reader and SD card just like it treats an external hard drive. Either drag-n-drop or copy and paste your pictures from the SD card file to a file on your hard drive. If after you have copied and backed up your files you want to reformat your SD card, replace it in the camera and format it in the camera, not in the computer. SD cards formatted in a computer will often not work in your camera because of slight differences in the formatting.
Cameras Logo
Trying to transfer photos to computor, hit transfer and it comes up Failed to initialize pluto. Don't know what to do.
You didn't say what software you are using, but there are better ways to download your photos. The best way is to connect your SD flash memory card to the computer. If your computer has a SD card slot you are in luck. If not, you can buy a USB SD reader for under $20 on line or in any computer store.
To use it, remove the SD card from your camera and insert it in the reader. Your computer will automatically recognize the SD card as an external memory device; exactly as it does with an external hard drive. You can then open the SD card and access the folder with your pictures. All you need to do is copy and paste your photos from the SD card to a new folder on your computer. It's that simple. Almost all professional photographers use this method and do not transfer pictures from the camera with the SD card in the camera.
Aug 17, 2015 | Nikon D5100 Digital Camera
Help me import from nikon cool pix s210 to Wlndows Live Photo Gallery 2011....laptop not recognizing camera
The best way to transfer pictures from a camera with an SD memory card is to do it outside the camera. If your computer does not have an SD card reader built in, you can buy an external USB card reader for $20 or less on E-bay, Amazon, etc. Remove the memory card from the camera and insert it in the card reader. Your computer will treat the card reader and SD card just like it treats an external hard drive. Either drag-n-drop or copy and paste your pictures from the SD card file to a file on your hard drive. If after you have copied and backed up your files you want to reformat your SD card, replace it in the camera and format it in the camera, not in the computer. SD cards formatted in a computer will often not work in your camera because of slight differences in the formatting.
Jul 19, 2014 | Nikon Coolpix S210 Digital Camera
how to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
545 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
