Tip & How-To about Audio Players & Recorders
Speakercraft Vital 1250 Class D amplifier
The Vital 1250 is a class D amplifier designed to deliver 170watts per channel (x12) at 4 ohms impedence.
There is however a number of these which are starting to come through with amplifier modules that fail.
There are 6 stereo class D modules using the TDA8970 design.
In breif the issues are down to the transformer secondary windings delivering slightly over spec voltage to the modules. Over time with the audio sense active this initial pulse from the transformer at power up sees off the amplifier chip and in many cases damages the PCB links between the double sided print making it impossible to remedy the exsisting module, so replacement is the only option.
The transformer on this unit is unique to this model and give 6 pairs of outputs for the 6 modules supplying 2x 29V AC which when converted to DC is around 41Vdc to each module, this can surge up on power on for a split second.
The TDA8970 is designed to take an absolute maximum of 39V and there is little or no protection on the output stage to stop a DC output occuring on the speaker outputs.
My therory is that this will be only the case for UK owners on a 240v mains supply as the tollerance may be acceptable for USA 110V users.
I have repaired these units by replacing all 6 modules with better units that have additional output protection between the TDA8970 and the speaker outputs. also adding resistors to the supply rails to help bring them in line with the correct tolerance and give longer life.
I am an engineer at MusicView Services and we speacialise in high end audio products and profesional music sound equipment.
I hope this helps someone with this amp, these problem will be specific to this model and should not be considered to relate to anything other than the Vital 1250.
what is the speaker load impedence of the speakers
Looks like you can use minimum 2 ohms, max 16 ohms
LFC Impedance Sensing
CS Series amplifiers feature innovative circuitry for safe operation into any load. When an amplifier senses a load that
overstresses the output stage, the Load Fault Correction circuit adjusts the channel gain to a safe level. Extreme load
fault under high power levels will cause the signal to be muted for the associated channel. This method of outputstage
protection is far more effective than the standard limiting found on conventional power amplifiers. The LFC
circuit is sonically transparent in normal use and unobtrusive when activated.
Jun 20, 2014 | Peavey CS 1400 Amplifier
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Subwoofer Dual voicecoil wiring
1 ohm will draw too much current.those are designed for a 2 channel 2 ohm drive for each sub.running 4 ohms will be easier on the amplifier and since impedance is not constant it may run 3 ohms at some frequencies anyway. another solution if your power amp is bridgeable....put the coils in series on each woofer making 4 ohms.then parallel the two 4 ohms to make 2 ohms and run the amp in bridge mode at 2 ohms.since bass is omnidirectional,you can do it
Jun 13, 2009 | PPI DCX-500.2 Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
pioneer prs-d5000spl
This sounds like an amplifier that trying to push a lower impedance load than its supposed to. Typical aftermarket car speakers have a 4ohm reading per voicecoil. By running more than one speaker per channel you can get more power(sometimes alot more) from the amp by feeding it a 2ohm load or more. If the amp isn't designed to handle ratings less than 4ohms a channel it will overheat and shutdown.
Mar 20, 2008 | Pioneer PRS-D5000SPL Car Audio Amplifier
748 people viewed this tip
 Grubhead
Grubhead
