Tip & How-To about Electrical Supplies
Use relais to get 24V from two 12V batteries
2 relais of type SPDT (or SP CO) + 3 diodes + a simple ON/OFF switch is all you need to switch two separate 12V batteries to have an output of 24V without having to rearrange battery cables. I can send a PDF-drawing for details.
Electrical Supplies Logo
Wiring help
Could you strip back the the output cable about 3/4" and separate each conductor so that I can see them? Was there any indication of what the system voltage was? 12V? 24V? It should be fairly easy to fixya up. Tx, Petra
Jun 15, 2013 | Home Security
wiring diagram for Harmar AL600 Lift
understand but no wiring picture found for this simple circuit
Mar 30, 2012 | Harmar AL600 Hybrid Platform Lift
Sharp lc 60e88un shutdown the 24v from power board no 12v
to check for led eror vol_ channel+ hold and press power switch once andrelease only power switch triangle light should come on then release the vol and channel knobs if set comes on the leds defective in screen
Mar 02, 2012 | Sharp LC Televison & Video
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
solar connections for 12vdc houseboat system
Based on your post/description, I would suggest that:
1. There is no need to install a diode from the boat motor alternator since most current design used electronic regulators with built-in diodes. The output of the alternator therefore could go straight to the battery or a switch (*selecting battery 1 or 2);
2. It would probably be safer that you would install a diode after a portable generator since some design do not need/use internal rectification but are connected straight to the windings/coil;
3. There is no need to install diode after each solar panel.
To my understanding the Plasmatronics have built-in in-line diodes to its inputs/outputs (unless otherwise required such as with the "Catch Diode protection" across the load). Additionally, unlike in some other system, a PL-20 would require that the negatives not be tied to a common ground. The PL-20 is relatively a straight forward connection (it's the programming that is a challenge).
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Tight lines.
Feb 01, 2008 | Radio Communications
239 people viewed this tip
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
