Tip & How-To about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
Toner Bottle Issues for the Di450/550 Copier
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KNUB on the side of the bottle is damage put a new one in that KNUB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
code error c0700
Open close the front door. If that does not work , power off the machine, remove the toner bottle, be careful if the hole is on the bottom when you pull it out toner is going to go everywhere. With bottle out and front door closed turn on the machine. Let it go through its normal warm up. If the code appears open close front door. When the machine asks for toner install the bottle correctly, if the nubs on the bottle are damage get a new bottle those nubs are what the toner bottle motor uses to turn the bottle. If the code still comes back you need either a new motor/sensor/or accurator worse case a new control board.
Dec 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
code c0072 at Minolta ep 4000
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the cover and turn on the machine. Let the machine go through it normal routine. IF code appears open close front door,When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Sep 23, 2013 | Minolta EP4000/5000 CS/PRO Copier
my photocopy machine shows code C0070
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad. Reset open close front door WHAT MODEL IS THIS MACHINE?
May 24, 2012 | Minolta Office Equipment & Supplies
code error c-0072 on minolta di450
Sir/Mam, Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If this does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Mar 26, 2012 | Minolta Office Equipment & Supplies
minolta ep3050 copier malfunction detected error code c0071
Sir/mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Feb 07, 2012 | Minolta Office Equipment & Supplies
2,197 people viewed this tip
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
