Tip & How-To about General Electric Universal Remote Control
CODES FOR BLUE RAY AND DVD
DIRECT CODE ENTRY
1.Locate the Remote Code List [ link bellow ] provided in this manual. Circle all the codes under that brand. Example: For a GE TV, locate the TV code section then circle all of the GE TV codes.
2. Manually turn on the device you wish to control.
3. Press and hold the SETUP button until the red indicator light stays on (approximately 4 seconds) and then release the SETUP button.
4. Press and release the desired device button on the remote (TV, DVD, CBL/ SAT, DVR/AUX). The red indicator will blink once and then remain on.
5. Enter the fist 4-digit code previously found in the code list using the number buttons on the remote. If the code entered is a valid code, the red indicator light will turn off. If the code entered is not a valid code, the red indicator light will flsh and remain on allowing you to re-enter the code.
Note: If no buttons are pressed for 10 seconds, the remote will exit the SETUP mode and you will have to start over.
6. Point the remote at the device. Press the POWER button-if the device turns off, no further programming is required for that device. If the device
does not turn off, return to step 3 and use the next code found in the code list. Continue this process until a code for your device is found.
7. Repeat this process for each device (for example TV, DVD, CBL, SAT, DVR, AUX) in your home entertainment system you wish to control. Four devices can be programmed.
PROGRAMMING NOTES FOR DIRECT CODE ENTRY
#If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
# Sometimes the fist code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
# With the Direct Code Entry method, you can program any device button to control any device in your home entertainment system.
For example, you can use the DVR/AUX device button to control an audio receiver or a DVD, VCR, satellite device, etc.
# For combination devices, you may have to enter a code for each device. For example, for a VCR/DVdevice, you may have to enter a code for the DVunder the DVD button and enter a code for the VCR using a different device button on the remote.
# Write down the code found to operate your device for future reference.
Codes
Electronics Equipment Repair Center
General Electric Universal Remote Control Logo
how do i program the RCRN04GR universal remote to a sylvania tv?
Hello
Here is the proceedings for direct code entry.
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method
TIP: Each device key is associated with a type of device-
the TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD•VCR
for DVD players, and DVR•AUX for DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
1. Manually turn on the device you
want to contro
2. Find the Code List that came with
the remote. Locate the section for
the type of device you're trying to
program, and find your brand in
that section. Circle the codes for
your brand and keep them handy.
3. Press and hold the device key you want to program (the
POWER key illuminates).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the POWER key turns off after the first digit).
4. When you've finished entering
the five-digit code, keep holding
down the device key and look at
the POWER key.
Is the POWER key
illuminated?
YES: You're done! You've programmed this device key.
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists
or missed a step in the code entry procedure. Try step 3
again
NOTES
Test the remote with the device to make sure the device
key is programmed with the correct code for maximum
functionality. If some features don't work, try a different code
in the list.
Remember to enter the code for future reference in the box
provided in the Code Retrieval section of this manual.
If your brand isn't listed in the code list, use one of the Code
Search methods to program the remote control. (Refer to the
Auto and Manual Code Search methods.)
If you release the device key any time during the Direct Code
Entry procedure, the POWER key blinks four times, and the
process is exited. The last programmed code under the
device key is retained
Codes to check with Sylvania are:
20035, 20081, 20000, 20043, 20593, 21593
11864, 10054, 10171, 11271, 11314
51563
OK.
Aug 29, 2011 | RCA RCRN04GR Remote Control
I need to know how to program my nexxtech 5 in 1 Universal remote control Cat # 1519004 to my T.V which is a Toshiba
Directly from the manual:
Code Programming
The P (Program) button is used to program the remote. You can program the remote using the code for your brand of device from the code list, or search through the library of codes until you find a code that works for your device. You can store any kind of code under any mode (except TV). For example, you can store a VCR code under the SAT button, or a DVD code under the VCR button, etc. However, you can only store TV codes under the TV button.
Direct Code Entry
1. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays
lit.
3. Enter the 3 digit code from the code list. Note: The red indicator turns off after a valid code entry and flashes for an invalid code. 4. With your device on, press Channel Up. If the device responds, no further setup is required. Note: If some buttons on your device do not operate, try one of the other codes for your brand.
Toshiba TV Codes
0159, 0178, 0109, 0120, 0181, 0105, 0049, 0095, 0170, 0260, 0358, 0394, 0924, 0012, 0095, 0117, 0141
You can download the fuel manual and code list here: http://files.remotecentral.com/download/472/1519004-manual.zip.html
Jun 01, 2011 | Televison & Video
universal RCA remote code needed for DYNEX tv
Hello
Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv.
Codes are
11463, 11810, 12184
Direct Code Entry
methods, but it's potentially the fastest method.
TIP: Each device key is associated with a type of device-the
receivers, cable boxes or digital TV converters, DVD for DVD
players, and VCR•AUX for VCRs and DVRs. To program a
The ON•OFF key serves as an indicator light during
programming, giving you feedback at each stage of the
process
want to control
ON•OFF key comes on).
code list (the ON•OFF key goes off after the first digit).
4. When you've finished entering the five-digit code, keep
holding down the device key and look at the ON•OFF key.
Is the ON•OFF key on?
either entered a code number that is not in the code lists or
missed a step in the code entry procedure. Try step 3 again.
Entry procedure, the ON•OFF key blinks four times, and
the process is exited. The last programmed code under the
device key is retained.
in the list.
OK.
Feb 22, 2011 | Dynex Televison & Video
What universal remote is acceptable for a toshiba 19A21 tv?
Hello
You just buy an RCA Universal Remote Control
Mosel numbers are RCR 412BN / RCR 412SN / RCR 412SIN. All of these remotes have listed Toshiba codes to suite to wirk with it.
Codes are:-
11524, 10154, 10156, 11256, 11265, 10060
Direct Code Entry
want to control
process
NOTES
in the list.
OK
Nov 30, 2010 | Toshiba 19A21 19" TV
RCA RCR412b remote
Direct Code Entry
To program your universal remote to control your components using the
Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you
want the remote to control (TV, VCR,
DVD, satellite receiver or cable box).
2. Locate the enclosed Code Lists. Find the
list for the component you wish to
program. Find your component’s brand.
You will see a listing of four-digit codes
for each brand. If your brand isn’t listed,
use one of the Code Search methods to
pages 7-8 for Manual and Auto Code
Search methods.)
3. Press and hold the component key (TV,
DVD, VCR·AUX, SAT·CBL) you wish to
program. (To program the VCR·AUX key
to control a component other than a VCR,
see page 7.) The illuminated ON·OFF key
turns on and remains on. If you release
the component key any time during the
Direct Code Entry procedure, the
illuminated ON·OFF key blinks four
times, and the process is exited. The last
programmed code under the component
key is retained. Toshiba codes:2011, 2029, 2030, 2033, 2093, 2107, 2110, 2111, 2112
Sep 13, 2009 | Televison & Video
600 people viewed this tip
Top General Electric Televison & Video Experts
Martin Murray
Christopher Stearns
Are you a General Electric Televison and Video Expert? Answer questions, earn points and help others
