Just buy an HDMI to AV converter box. It will converter the HDMI to Composite video. If your TV have Component video input then its better to buy HDMI to Component video cable. component video quality is better than composite. Its have resolution up to 1080i.
please try to add details like what you want to know. then only anyone will be able to provide you better answer... Electronics Equipment Repair Center
In other words, it is dead. Check and replace the main power regulator board. If you are not familiar with
electronics, do not attempt to repair.
Whether you sufferfatal
electrical shock. Instead, contact
any experienced service technician, or the nearest service center. If
you wish to get more details, check this site linked below. Pull up older posts
there. Check the site with patience, as
it has over 2350 posts now. All are
related to electronic equipment repair help.
If you search the site in Timeslide option, which can be selected from
the drop down list at the top left of the display window, it will be easy to
locate the related post. You can also
do a search by type in the brand name
and model number to your device into its search box at the top right of display
window.
