Tip & How-To about Computers & Internet
HOW TO REMOVE Playzy Adware
1. Restart your PC before windows launches, tap "F8" constantly. Choose "Safe Mode with Networking" option, and then press Enter key.
2. Press Ctrl+Alt+Del keys together and stop Trojan horse Generic34.aspc processes in the Windows Task Manager.
3.Remove files associated with the Trojan horse:
%AllUsersProfile%\Application Data\.dll
%AllUsersProfile%\Application Data\.exe(random)
4. Search for all related registry entries infected by Trojan horse Generic34.aspc and wipe them out:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Temp
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\LowRegistry
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
5.Reboot the computer to normal mode when the above steps are done.
resources from :
http://www.gblade.com/how-to-remove-playzy.html
Computers & Internet Logo
start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Locked up on restart... How do I solve this mess????
Sony's Vaio line of laptop and desktop computers ship with the latest version of Windows installed. Even the best designed Vaio computer can sometimes malfunction, occasionally in connection with an error in Windows. Boot your Vaio computer in Windows' "Safe Mode" to disable potential problem-causing drivers and programs to help you troubleshoot and fix your Sony computer.
Windows XP Press the power button on the Sony Vaio computer, typically found in the top right corner of the laptop's keyboard panel or on the desktop's tower. If your computer is already on, press "Start" in the lower left corner of Windows XP and press "Turn off computer." A new window will appear. Press the green "Restart" icon. Hold down the F8 key on your Sony Vaio's keyboard as soon as your computer's screen goes dark. A new window, labeled "Windows Advanced Options," will appear. Choose one of the Safe Mode options listed. "Safe Mode" loads the minimal amount of drivers, while "Safe Mode with Networking" also loads your networking preferences. Press "OK." b> Windows 7 Press the Sony Vaio computer's power button if it's off, or restart the computer. Click "Start" in the lower left corner of Windows 7 and choose "Shut Down." A new window will appear. Push "Restart." Press and hold your computer's F8 key. A menu called "Advanced Boot Options" will launch on the screen once the restarting process is complete. Choose "Safe Mode" or "Safe Mode with Networking" and press "OK."
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 15, 2013 | Computers & Internet
How to enter the safe mode with network, which key should i press, please help
Hi chankp,
Welcome to FixYa! How are you doing?
Please try to do the following to boot your pc to safe mode with networking:
  • Turn off the computer. Turn on the computer then immediately start tapping the F8 key repeatedly.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Use the (Down Arrow) arrow key on the keyboard, scroll down to Safe Mode with Networking then press Enter.
  • Login to your User Name.
Hope that helps. Thank you for using FixYa!
Apr 27, 2011 | Computers & Internet
how do i get into the safemode on the gateway 7405gx laptop
For any windows computer its always F8.
But some times there are few boards which are designed to launch Device Boot Menu when you press F8. If you are struck with this kind of screen,
Then Choose the Hard Drive from the List then Press Enter and immediately start tapping F8 you should get the advanced boot menu now. Make you choose the Hard Drive from the list then press enter then immd start tapping F8. That's it
Feb 04, 2011 | Computers & Internet
how do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
948 people viewed this tip
David Payne
David Payne
