Tip & How-To about Home
Toto SW834r Remote Control Problem
Note: Toto does not sell parts and requires dending in a unit with a maximum repair price of $300 as of 1/.2015If after replacing remote batteries the seat still does not respond, try the following:1. Turn off the water shut off valve at the wall and unplug the power.2. Unscrew the water inlet hose to the seat.3. Unsnap the seat from the toilet by pushing the quick release on the side of the seat neat the hinge on right side facing the toilet.4. Bring the seat to an area you can get dirty (outside) and remove the two stainless screws on the rear of the seat.5. Carefully unsnap the cover  (four plastic clips inside the cover)6. Clean everything inside and out including water filter on side (unscrews), air filter underneath, top of toilet,  and rinse and allow to dry thouroughly.7. While drying carefully unclip the remote sensor and remove the connector by holding the lock and pulling straight off. Confirm there is no corrosion on the connector. Use a contact cleaner/protector and clean the contacts and replug in the connector.8. It is also recommended to do the same for all of the other connectors.9. Put everything back together.10. Replace hose and plug in power and allow "restart" to finish11. Test remote to see if remote "talks" to seat before turning on water.12. Turn on water and wait for inner tank to fill.13. Manual controls on side of seat can be used to confirm unit is working.  After confirmation the remote should work normally.14. After this procedure my SW 834r worked perfectly......  enjoy.
Home Logo
CCD failure
Sell your camera for spare parts, the fault requires a professional repair costing far more than the camera is worth. Note that you'll get more by selling the battery, body caps (hotshoe cover, sync socket cover, lenscap) and camera body as separate items.
Sep 10, 2011 | Konica Minolta DiMAGE A1 Digital Camera
1987 chevrolet s10 4wd automatic transmission. 4wd low is perfect, 2wd and 4wd high drives 100 to 500 yds then pops into neutral and grinds gears.Any adjustment?Can you dend exploded parts breakdown?
You will have to remove the transfer case &
disassemble it, to make repairs
Drivetrain.Com -- seems like a good site
for transfer info
There should be a local wholesale trans
supply house near you for parts
This is just a facebook type site,we are at home
Do not have or sell anything
Jun 18, 2011 | 1987 Chevrolet S-10 Pickup
fan remote receiver number UC7051R has failed
I find no replacement parts outlets. But you are in luck because Lowes and Home Depot sell replacement remote units that you can replace yours with. Choices vary but all will offer
the full range of controls including lights, dimming and speed control. Just requires a little DIY and
always turn off the breaker before repairing. Good luck.
Apr 01, 2011 | Aloha Housewares (93645) Ceiling Fan
995 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
