Tip & How-To about Dishwashers
Make unloading dishwasher much easier
My wife is brilliant. She loads the silverware in a way that I never thought of, but is very smart. I am sure most of you have already thought of this, but, I had not. She puts forks together, spoons, and knives together.Odds and ends together. When unloading, I grab all of the forks and tap the handles on the counter. This exposes the different sizes, and makes unloading much faster.
Dishwashers Logo
A magnet the size of a quarter was in my dishwasher stuck to my silverware. This is 1 week old and I don't know where it goes.
I would save it and if everything works properly not even give it a second thought .sometimes in manufacturing they lose parts and can not find them .
Dec 16, 2015 | Whirlpool 24 in. DU1100XTP Built-in...
door will not shut when upper silverware holder is in
Make sure you are installing that silverware holder properly. The little tabs of the silverware holder are supposd to go over and around the mating bars of the upper rack. Barring that, your upper rack may be pulled (bent) out, and you may have to push it (hard) to get it back in shape.
Oct 30, 2014 | General Electric Adora GHDA670N Built-in...
Clear glasses and silverware have film and some particulates. Silverware is on bottom and glasses on top. It's a KUDS03FTSS3. Have had the filter area cleaned. Have used vinegar. Have used less soap, more soap, powdered soap. Unit is 3 years old. The problem happened suddenly. Suggestions? Thanks
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Nov 12, 2010 | KitchenAid Dishwashers
film on my dishes and silverware
the detergent is not breaking down,it could be hard water try cleaning the soap dispenser,also try vinegar or CLR and run with no dishes.clean out sprayer arms make sure the wholes are not blocked up,and before loading machine rinse off dishes before loading.
Jul 08, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
238 people viewed this tip
Top Dishwashers Experts
